Vacuum Advance Question...
Old Oct 3, 2002 | 09:00 PM
jbulson's Avatar
jbulson
So I went to try out my new vacume pump the other day and decided to hook it up to my vacume advance on my 360.. When I hooked it up and got no seal what so ever, I figured my vacume advance was bad. So I go to the parts store and they have 4 different dizzy's to chose from, asking about if I have a governer and if so what kind?...my question is, how do I tell if, and what kind of governer I have. This is a 76 hi-boy with a pretty much stock 360 4v holley 4150. Any help is awesome!!!!!
Old Oct 3, 2002 | 09:19 PM
Mil1ion's Avatar
Mil1ion
Can you give me the distributor number?
It's the D6TE-12127- ? number suffix, I'm looking for.
Btw, I changed the spelling of Vacuum so future user searching the threads will find it.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Oct 3, 2002 | 10:05 PM
jbulson's Avatar
jbulson
where exactly would I find the nuber?
Old Oct 3, 2002 | 11:19 PM
Mil1ion's Avatar
Mil1ion
It would be on the side of the metal body(stamped in) .
There were 5 different vacuum advance's for the 76 >360.
[/font]
Old Oct 4, 2002 | 07:43 PM
jbulson's Avatar
jbulson
[updated:LAST EDITED ON 04-Oct-02 AT 08:46 PM (EST)]I take it the dizzy has to be removed to see these numbers? I was looking on the side and didnt see any...I looked at the parts stores and there is only one with single vacuum advance...is there a way to tell this? I only have 1 advance unit and there is only one line attached to it...Is this my part? or do I need the numbers?I dont want to pull my dizzy andmore than I hace to cuz my oil pump driveshaft likes to fall into the oil pan...Gotta get the right one of those too...
Old Oct 4, 2002 | 08:24 PM
Mil1ion's Avatar
Mil1ion
I've tried to help you with specific information.
Ford has certain specs for each thing they make.
Some can get you by,some can't.
It's now your choice.
Distributor number with Vacuum Advance Motorcraft application number
D5TE-12127-EA = DD-719
D5TE-12127-PA = DD-730
D5TE-12127-ZA = DD-730
D5TE-12127-ASA= DD-721
All these dizzie's share the same Cap,Rotor,Module,Stator,Armature, Coil & SERVICE dist.
The ONE thing they do not share is the same Vacuum Advance.
I would suggest looking close to see what dizzy you have.It is on the Main Body where the spring clips are held on.
[/font]
Old Oct 4, 2002 | 09:21 PM
jbulson's Avatar
jbulson
[updated:LAST EDITED ON 04-Oct-02 AT 10:25 PM (EST)]ok. I looked on the housing Behind the clips and the only # I found was a 12127, right above the word motorcraft I looked very closely around the top rim around to the other side and behind that clip too and from what I can tell there are no more numbers.I Guess I will just have to pull it out and look closer. Thank you for you paitence, I know I will get this resolved.
Old Oct 4, 2002 | 09:41 PM
Mil1ion's Avatar
Mil1ion
Get all the numbers either side of the 12127 number.
If you find them e-mail me directly.
[/font]
Old Oct 5, 2002 | 09:58 AM
mjodaly's Avatar
mjodaly
Dace
Apr 29, 2023 04:52 PM
southwest395
Dec 20, 2020 11:05 AM
jbancroft
Jul 6, 2014 03:52 PM
skytrash
May 11, 2014 05:05 AM
73'360f100
Dec 15, 2011 08:43 PM
