cooling system problems
Old Aug 13, 2005 | 07:44 PM
baxy's Avatar
baxy
1996 f150 4.9 5speed A/C
after a short while of driving the cooling system develops alot of pressure
the pressure actually caused my old rad to burst at the plastic tank seam and now it is pushing its way out the t-stat gasket
the upper hose is hard as a rock all the time, poor circulation throught the heater core
and the temp gauge always shows low like barelt to the fist notch maybe 1/8 inch up on the gauge
it has
new coolant
new rad 4 core
new t-stat
new belt installed correctly for A/C
I'm thinking it will probably soon blow up the heater core (ugly)
anyone come across this before
Old Aug 13, 2005 | 08:14 PM
Beechkid's Avatar
Beechkid
Check to see if the new thermostat is defective...I would change it anyway even if it's new & secondly check the lower radiator hose to see if it is collapsing....in the old days they use to have wire inserts running inside the lower rad hoses to prevent collapse but those are almost gone.....sound slike a definite possibility to cause a large psi build up
Old Aug 14, 2005 | 08:52 AM
baxy's Avatar
baxy
done that I'm on the third t-stat with same problem
origional,1st replacement and 2nd repalacement
I'm not getting bubles in system but there does seem to be air in the system even after extensive effort to bleed it
Old Aug 14, 2005 | 09:21 AM
Beechkid's Avatar
Beechkid
Probably time then to get some dye for the radiator and check for leaks (including possible head gasket) but I would rule out the lower radiator hose collapsing first.
Old Aug 14, 2005 | 09:30 AM
Spaznaut's Avatar
Spaznaut
Those hoses would collapse at high rpm. If it has all this pressure at idle than its hard to tell. Anytime a system is hot its going to be under pressure. It depends on how high you rad. cap is rated as to how high it'll go before it'll release. You never did say what psi your cap was. If your heater core is rotted or weak it'll bust no matter what. Just ask all those that have had to replace em . Sounds like you have a possible head gasket problem. However your cap shouldn't let your system over pressurize. Like a pop-off valve on a water heater. I think there are some posts around here on how to pressure test the system. I'm not familiar with em...yet.
Old Aug 14, 2005 | 09:42 AM
baxy's Avatar
baxy
cap is new ford stock replacement I think 14 psi
I'm going to get at the head gasket I think
just wanted to know if anyone else has come across this problem
Old Aug 14, 2005 | 10:26 AM
dybeepvw's Avatar
dybeepvw
Check your fan clutch and you might need another water pump, sounds like a blockage somewhere.
Old Aug 14, 2005 | 12:45 PM
baxy's Avatar
baxy
thats good idea I did kind of think about the possibility that someone has (before I bought it) a non A/C water pump
I think I would see major overheating if it was turning the wron way though
