Kwick or 6637 filter question
Old Aug 12, 2005 | 07:20 PM
LONEPINERON's Avatar
LONEPINERON
Just logged on to wix filters and compared the cfm of stock filter #46648 for 99 f350 to 6637 and it don't add up
Stock filter is 640 cfm
6637 filter is 425cfm
So how do you figure it gets more air through it. I have the 6637 on mine haven't really put it through the pases yet to see how much better it is but just short up hill around home the turbo sure seemed to like it.
Old Aug 12, 2005 | 07:30 PM
johnny8's Avatar
johnny8
i don't know what those numbers are, or where they came from... but i can tell you... there is NO WAY... NO WAY IN HELL.. that the 6637 flows LESS air than the stock filter...! NO WAY AT ALL..! oh... did i mention that there is NO WAY...!
Old Aug 12, 2005 | 07:31 PM
Kwikkordead's Avatar
Kwikkordead
Yeah, the thing's just HUGE compared to the stock filter.
Old Aug 12, 2005 | 07:37 PM
LONEPINERON
Go to fleetfilters.com look up the air filters by # in the WIX area and pull up the specs. Don't make scenes to me either.
LPR
Old Aug 12, 2005 | 08:13 PM
believer45's Avatar
believer45
Wix site shows the Wix part number for my AH1141 Fleetguard on my open element setup to be 46637 - goes to the 425 CFM rating.
If you do the search for the factory filter for a 1995 F250 'Stroke it shows 320 CFM.
I guess the newer trucks have a much improved filter?
Dave / Believer45
Old Aug 12, 2005 | 10:07 PM
SpringerPop's Avatar
SpringerPop
I'm with johnny8 on this one.
ABSOLUTELY NO WAY!!!
Pop
Old Aug 13, 2005 | 06:25 AM
rockyrider's Avatar
rockyrider
Here's some interesting reading on the subject. (Just the facts mam);
http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm
Old Aug 13, 2005 | 09:08 AM
clux's Avatar
clux
That is an interesting observation lonepine. Might just be a typo. I'll bet it's supposed to be 240 cfm, since the wix 3" pleat high capacity stock filter is rated at 260 cfm. But remember filter media is as important as surface area. The actual dimensions of the intake area of the AIS filter is a fair bit smaller than the stock filter, but they the media is like a 6" pleat so the actual filtering surface area is way more. Dale at Tymar has cautioned that the Tymar copycat filters are not as good filter media as his filter. Maybe he is right.
Old Aug 13, 2005 | 09:42 AM
greenhighboy's Avatar
greenhighboy
I installed the 6637 filter on my truck a few weeks ago. You can hear more air noise which is to be expected going from a box to an open filter. Last night I pulled an 11,000 lb. load for 150 miles and you could tell that it made quite a difference in EGT's and turbo stall was less. So I am happy with the change,$35 well spent. I just wish I could stick out through the fender for some FRESH air!
Old Aug 13, 2005 | 01:50 PM
SpringerPop
From what I can gather from the professional test results cited, the best thing I could do for my Powerstroke is to use the filter with the largest area and the most restrictive media. That way, I'd have plenty of better-filtered air.
But I already knew that. I know the 6637 fulfills one of these parameters.
Pop
Old Aug 13, 2005 | 07:18 PM
LONEPINERON
You know after looking through the WIX site some more they may have made a typo or something. Because the upgrade fore the Dodge air filter part # 42790 the dimensions are :
Height 11.88
outer diameter 10.5
inner diameter 4
cfm rated at 680
And the 46637s specs are:
height 12.38
outer diameter 8.5
inner diameter 4
cfm 425
Specs for stock # 46648 are
height 2.295
length 13.351
width 7.229
cfm 640
So maybe the one they recommend for dodge would be better it is 2" larger in diameter and 1/2 inch shorter but 255 cfm more.
Ill have to take a look but believe it will still fit in same place. Not saying that the 6637 doesn't work better just that the specs say it shouldn't and that maybe the option that they say is fore the dodge might be even better. On the down side it does cost about $10 more.
LPR
Old Aug 13, 2005 | 11:54 PM
Fis Teck's Avatar
Fis Teck
This is why I went with the Ford upgraded air filter on my 2000 Ford useing the Donaldson filter you get high flow with the best filtering.
Old Aug 14, 2005 | 10:23 AM
LONEPINERON
the 42790 filters principal Application is for the Donaldson Disposable Housing according to the spec sheet.
LPR
Old Aug 14, 2005 | 11:17 AM
BuickTurbo's Avatar
BuickTurbo
Surface area, the 6637 has more....a lot more than the stock filter.
Old Aug 14, 2005 | 12:29 PM
LONEPINERON
Fis Teck. Just what is the ford upgrade? How much does it cost, is it an open box type?
