94 ranger A/C challenge
Old Aug 12, 2005 | 12:15 PM
lisaul's Avatar
lisaul
I have a ford Ranger 1994, The A/c would be cold upon starting and then blow hot air after 5 minutes or so. Later..the engine ran hot, so I added antifreeze..Now the A/c works fine.How are these related?
Old Aug 12, 2005 | 12:22 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Welcome to FTE!!
Most likely the ECM (computer) noted the high engine temp and shut down the A/C as a form of protection.
Old Aug 31, 2005 | 05:16 PM
cooldad79's Avatar
cooldad79
I have a prob with my 94 ranger AC also. Drove it the other day worked fine. Stopped at red light and quit working. Full of AC coolant but compresser doesnt kick in. Don't have owners manual. Is there a fuse other than in the fuse panel to check. Help, hot here, lol
Old Aug 31, 2005 | 11:12 PM
AlfredB1979's Avatar
AlfredB1979
Buy a Haynes manual--it helps with Illustration 6-11 in Chapter 5 about AC troubleshooting. It will tell you everything to check. Especially which posts to check on the AC WOT relay. Very nice diagram....
Old Sep 1, 2005 | 05:50 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 1, 2005 | 08:23 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
The air conditioning condensor is a "mini radiator" used to cool off the warm freon after passing through the evaporator. It is situated directly in front of the engine radiator so the air flow can cool it off, as well as the engine radiator.
When the vehicle overheats, the heat from the engine radiator can transfer to the condensor and actually heat the freon up more, hence hot A/c.
Some cars will also shut off the A/C compressor if the engine reaches an overheat condition, once again resulting in warm air.
Hope this answers your question.
