Need help maintenance and lube recommendations
Old Aug 12, 2005 | 10:25 AM
jeremyd72's Avatar
jeremyd72
Hi all. I’ve searched the forum and still can’t find what I need pertaining to the old body style. I have just bought a 1997 F350 CC 4x4 DRW with a 5 speed with 115k on it and it didn’t have an owner’s manual in it. I need to know what front and rear end and transfer case it has under it. Also, what is the maintenance schedule for the truck and what lubricants and how much is needed for the engine, tranny, transfer case, front and rear end as well as coolant. Thanks for the help.
Jeremy
Old Aug 12, 2005 | 05:42 PM
tjbeggs's Avatar
tjbeggs
i am pretty sure you have a dana 70 (not real sure about that one), a dana 60 front end. both take gear oil up to the fill plug. probably about 3 quarts each. the t-case uses atf up to the fill plug. your trans is a zf5 and i think it uses regular atf to the fill plug. your engine hold 14 quarts with a filter. coolant is regular green coolant with cavitaion preventative additive. engine oil changes at 4 to 5000.
maybe somebody with more knowledge of a dually can help you on the rear axle.
