Hi, I am going to replace the bushings in the front end of my 76 f 150 4x4 after realizing the Po installed everything loose. I found out via the dreaded death wobble. Aniways, I am looking at Jeff's Bronco Graveyard, and they have a "c" bushing set that includes the strut arm bushing, I am wondering if that is the same bushing as the radious arm bushing, if it isnt, then where does this bushing go? ( Im a newbie ) also I cannot seam to find tie rod bushings, any ideas?
Ps when I replaced my shocks, the rs 5000's that fit were for a 2" inch lifted truck, I have some blocks (ugggghhhh) right under the spring pearches is this factory? The truck apears to sit about 2 inches higher in front .
Thanks for your help,
JA
Reason: Spelling
