Aussie Heads Installed & Running
Old Oct 11, 2002 | 05:01 PM
76swb's Avatar
76swb
Patrick, been around a 351 cleve long enough to know you need 10-12' btdc with a stock cam. 34-36 total works well for me. I think your ping is related to your push rod length. Measure what you have, get the next shorter size from napa. Combine it with shims to shorten original rod length .020- .040. You want to reduce clatter to an acceptable level, not necessarilly eliminate it. Shorten as necessary. 600 cfm is plenty.
