1978F250 4x4
Old Oct 10, 2002 | 02:52 PM
irondragon79's Avatar
irondragon79
1978F250 4x4
Old Oct 11, 2002 | 09:04 AM
deputydawg's Avatar
deputydawg
1978F250 4x4
How hard is it to change the 2u joints right in front of the transfer case ( the ones that are close together with the short joiner peice) and what is that part called? By the way great site to find stuff out THANKS
Old Oct 11, 2002 | 11:38 AM
tw's Avatar
tw
1978F250 4x4
Do you mean the driveshaft? Not sure of the question.
Tony Warren
Nebraska
Old Oct 11, 2002 | 12:17 PM
jalampi's Avatar
jalampi
1978F250 4x4
Some call it a C/V joint?? I takes about the same amount of effort to change them. The ball and socket is probably worn out also.
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,L&L Ladder Bars,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
Old Oct 11, 2002 | 05:14 PM
79_250RangerLariat's Avatar
79_250RangerLariat
1978F250 4x4
Thought it was a velocity joint.... It's not that bad, just like any other 20 yr old U joint
