Expedition Stall
Old Aug 11, 2005 | 03:33 PM
jstephens9664's Avatar
jstephens9664
Cool Expedition Stall
I have a 1999 Expoedition and it stalls while sitting at a red light. It will crank but not catch until after sitting for a few minutes. After restart it runs fine
Old Aug 11, 2005 | 04:12 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 11, 2005 | 05:04 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
What engine do you have??
Old Aug 11, 2005 | 08:55 PM
jstephens9664
I have the 5.4 Liter. I drove it home today and it was perfect. Both times the vehicle was on an incline
Old Aug 12, 2005 | 11:09 AM
200cs's Avatar
200cs
Are you getting any check engine lights? have you visually inspected the engine compartment for anything out of order? More information would help...
Old Aug 12, 2005 | 12:29 PM
l-m tech's Avatar
l-m tech
check the pcv system out.the rubber elbows usually got soft and cause a vaccume leak the will cause the engine to idle low or stall.this is a common problem for high mile exp./nav.
Old Aug 12, 2005 | 02:35 PM
jstephens9664
I work for an Acura Dealer and we hooked it up to the OBD II Hds tablet and
there are no error codes stored. We checked the data list and everything seems normal. I also checked for vacuum leaks and fuel pressure. We run into main fuel relays that act like the Expedition does, thanks for the help
Old Aug 12, 2005 | 04:53 PM
99FordGuy's Avatar
99FordGuy
I have a 99 Navigator that is stalling also. It will crank back up , but if you don't keep your foot on the gas it will stall again. I checked the vacuum hoses and found several bad elbows in the line that had gotten soft and collapsed. I changed them but it still does the same thing. The AC vents also change from vent to defrost sometimes ( Don't know if it's related but started about the same time). Any ideas?
Old Aug 12, 2005 | 04:56 PM
jstephens9664
The Changing Of The Vents Is Only Related If There Is A Vacuum
Leak To The Dash. Usually It Is A Broken Blend Door. I Had To Fix Mine Also.
