spark plugs????
Old Aug 15, 2005 | 03:52 PM
chevygoneford's Avatar
chevygoneford
Unhappy
head gasket on 1and 2 cylinders had water in them got the heads off and theres a pretty good lip in the cylinder walls think im goin to just rebuild this one and call it a day
Old Aug 17, 2005 | 07:22 PM
TigerDan's Avatar
TigerDan
Okay, sounds like a plan. Going to do any upgrades while you're in there? Cam, double roller timing chain, that sort of thing?
Old Sep 11, 2005 | 08:53 PM
chevygoneford
Unhappy made it worse i think
got the engine from friend installed and put everthing from mine to it and now after all the work it wouldnt start tried the 302 firing order nothin tried 351 got a little running but had to play with the gas to keep it goin and still got some backfires not shure check everthing list new plug wires cap roter double roller timing set gaskets oil its supposed to be a 302 but what would be the chance that it could be a 351? turns over good fuel pumps are runnin but have to play with gas to keep it goin check all plugs went over everthing just dont know any help would be great
Old Sep 11, 2005 | 10:30 PM
TigerDan's Avatar
TigerDan
Sounds like the distributor is a tooth or so off. User subford wrote up an excellent description of installing the distributor here:
https://www.ford-trucks.com/forums/s...d.php?t=406468
Give that a shot and get back to us.
It might be a 351, but you would probably have noticed the difference, especially if you put your accessories and such on it. I don't believe everything would have fit too well. The 5.0 HO uses the same firing order as a 351, and some aftermarket cams are ground to use that firing order as well. The cam might have been replaced at some point, or the Bronco (you did say it came from a Bronco?) might have had an HO motor swapped into it. Did you use all your EFI parts off the van, or did you use anything that came with the Bronco motor?
Old Sep 12, 2005 | 05:01 PM
chevygoneford
Question is it possible????????????????
I used all the parts from the van but my question is is it possible to get the crank 180 out from the cam doing a timing chain?
i brought it up to tdc and marked all of the stuff today still wont run have to play with the gas and acts like its fighting itself i know everything is right on but i had that question floating around in my head thanks
Old Sep 12, 2005 | 06:21 PM
TigerDan's Avatar
TigerDan
Well, you could get the crank and the cam 180 off on assembly, but since they are on 2:1 ratio, they'd be back on in one revolution. If you've got anything off by a large amount, it won't run at all but if the cam is one tooth off it'll run, but poorly as it will if the distributor is a tooth or two off. The thing with the distributor is, if it's off you can can adjust it to a certain extent, till you run out of room to turn it.
Old Sep 12, 2005 | 06:39 PM
chevygoneford
Angry done it all runnin out of options
tried doin the tdc got it rewired starts but wont stay runnin have to throttle it
where do i pull the codes from? thanks for the help
Old Sep 12, 2005 | 06:48 PM
TigerDan's Avatar
TigerDan
I'm not sure where it would be on your van, but you need to find a little connector with a plastic dust shield on it labled EEC TEST.
Here's what it looks like:
http://fordfuelinjection.com/?p=13
Notice that in the pic, you're actually looking at the connector(s) that plug into the scanner. The cover that keeps them from filling up with dirt and oil is lying underneath and to the right of the connector in the first photo.
Old Sep 12, 2005 | 07:42 PM
chevygoneford
Exclamation reply
thanks ill take a look tommorow after i put some fresh gas in just a thought so let me understand this correctly the cam and crank are ok there is no way to get them out 180? the two dots get lined up cam dot down and crank dot up correct just tryin to cast away any doubt its a ford thing you know first timing set ive done on a ford and should have done this research before doing this job thanks again for your help
Old Sep 12, 2005 | 08:11 PM
TigerDan's Avatar
TigerDan
Right, the dots face each other. If you did that, then you got it as close as you can get it without a degree wheel.
Old Sep 12, 2005 | 08:22 PM
chevygoneford
Question bad gas ?
it sat since my first post think that could be it?takin shots in the dark now
Old Sep 12, 2005 | 09:52 PM
TigerDan's Avatar
TigerDan
We're only talking a month here...that's nothing. Yup, you're really grasping at straws now!
Wait till tomorrow when you're feeling fresh, check the codes and the fuel pressure and then we'll take it from there.
Old Sep 16, 2005 | 04:06 PM
  #28
chevygoneford
well did a compression check on it and only one cylinder came up low no. 7 all others was 150 no. 7 was 130 would that make a difference?
Old Sep 16, 2005 | 08:00 PM
  #29
TigerDan's Avatar
TigerDan
That's not too bad, really. Shouldn't be enough to make it run that badly.
Old Sep 18, 2005 | 12:30 AM
  #30
chevygoneford
Red face map sensor
well here i go again unplugged the map and walla it started ran and drove got to get a new one really glad i changed out the moter now this one has alot more power and runs alot quiter still have my other one goin to rebuild it and put it in my truck when th I 6 dies does this mean i just need a new map?or is it just one of those daisy chain sensors that feed of another?
