Sponsored by: Kumho
Swaybar help
Old Aug 11, 2005 | 06:15 AM
zzcharger's Avatar
zzcharger
Swaybar help
Hello guys and gals I am looking for some help/suggestions. I have a 91 f150 2wd and want to try some swaybars on the front and back. Does anyone know if these trucks came with swaybars? My creative mind is thinking about trying some from the junkyard off of a mid 80s bronco since the suspension is basically the same. the mounting points out by the wheels is what concerns me. they sit under the springs and on top of the beams. Are these removable and if so does anyone know if they are switchable? Well I just wanted some friendly advice, I may try no matter what since the junkman anly wants 35 for it. Thanks for any and all input, Jack
Old Aug 12, 2005 | 07:44 PM
F150'89's Avatar
F150'89
My '89 F150 2wd has front and rear sway bars, they may fit but don't know for sure.
Old Aug 16, 2005 | 04:24 PM
zzcharger's Avatar
zzcharger
what model
Just wondering what model you have, mine is an xlt lariet so i figured it would have everything, Have you seen any in junkyars or for slae?
Old Aug 16, 2005 | 09:22 PM
F150'89's Avatar
F150'89
Your '91 should have come with a front bar, don't know if all had rear bars or not. The www.lmctruck.com catalog that I have shows that the front and rear bars and mounting parts are the same from 1981 to 1991 if you have a standard cab. If you have a extended cab the rear bar will need to come from a ext cab truck. I don't know if the Bronco parts will work on the F150 but they may.
Old Aug 17, 2005 | 05:26 AM
F150'89's Avatar
F150'89
I forgot to add that if your truck is 2wd you will need parts from a 2wd and if its a 4X4 the parts will need to come from a 4X4.
Crewcab Turbo
Mar 11, 2012 07:04 PM
Bootlegger's Deluxe
Mar 3, 2011 07:31 PM
crestfallinman
20
Aug 25, 2008 11:05 PM
Rob
Sep 26, 1999 12:50 PM
