Oil & Lubrication
gear lube
Old Aug 11, 2005 | 04:31 AM
Gearheadjo's Avatar
Gearheadjo
Question gear lube
What is the difference between GL-4 and GL-5 gearlube. Is it just the weight or what. I have a tranmission that takes GL-4 and rear end that takes GL-5. Is it OK to use one or the other in both. Thanks for the imput.
Old Aug 11, 2005 | 06:30 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 11, 2005 | 11:03 AM
jimandmandy's Avatar
jimandmandy
GL-5 has extreme pressure additives for hypoid gearsets, GL-4 does not. Those additives contain sulfur compounds which are corrosive to "yellow" metals, such as synchro rings in older manual transmissions. It is not a good idea to use GL-4 in your rear axle. GL-5 may be used in transmissions if they do not have bronze or brass parts. Redline MT-90 is perfect for those transmissons that do.
Jim
john jamieson
Oct 21, 2020 11:21 AM
twtcad
Vehicles for Sale
Mar 2, 2016 04:16 PM
DasCheckers
Montana Chapter
176
Sep 1, 2014 10:43 PM
obscurity
Dec 8, 2013 01:05 PM
