Is a coolant filter necessary?
Thanks for the write-up... Just in time too. I should be getting my coolant filter within the next couple of days, and with what everyone says (your write-up included) I can schedule my installation for a "after work" project... Thanks again...
Are you installing only or flushing then installing?
Which set-up did you buy?
Have coolant on hand and use distilled water if just installing.
Good luck and way to go.
Jeff
Edit: I bought the dieselsite set with the valves.
We'll see...
Open degas bottle (cap) to relieve any pressure (if any).
Connect all pieces of the filter, valves and connections first.
Install braket to radiator bolts.
Install filter assembly onto braket.
Install return line into the small hose from radiator to bottle (no fluid will leak and is easily done).
Where you may get fluid loss is when cutting the heater line behind the oil fill tube (small area and hard to get large hands in there to make a straight cut/splice. Install "tee" and clamps.
Hook up to filter assembly (make sure to use teflon tape on all threaded connections.
Remember to coat the rubber gasket of the Baldwin filter with fresh oil (just like an oil filter) - The dieselsite instructions do not mention this.
Depending on fluid loss, you will need distilled water and maybe some coolant. The Ford Premium Gold coolant is $10.00/gallon. I would get some before hand so you can add back the proper 50/50mixture of your factory fill.
You will need the coolant later on anyway when doing the filter change, as you will loose a pint or less each time you change filters (FYI). The coolant will not go bad.
Being new, I am sure there is a bunch of sand and sediment from when the motor was casted. I would keep an eye on your degas bottle and change filters in 2 - 3 months to see what you are collecting.
Good luck,
Jeff
Hmm...2500 posts
SCA charged for 7.3L PSD motors and non-charged for 6.0L PSD motors.
As we all know, you can use non-charged on both motors and monitor and add SCA's as needed.
Jeff
My truck is running well and since the motor is warranted for 100,000 miles I will use the Ford Motorcraft Premium Gold Coolant as it works, is well made and would be covered if a cooling system, water pump or type failure was to ocurr. The Motorcraft Prem. Gold Coolant was $10.00/gallon at my Ford dealer, so I bought 4 gallons (needed 3-1/2 for complete flush)... and $40.00 was OK with me (not sure is Evans is more or less, but I will guess more!!)
I will change my coolant filter at 10,000 miles just to see and will flush my cooling system at 50,000 miles (again) as I believe that this is long enough and I received my monies worth spending $55.00 on a flush ($40 for coolant and $15.00 on 15 gallons of distilled water).
Good luck,
Jeff
I don't know if the spec meet Fords. but it does sound good when you read it.
Thanks for the input. John
I am sure it is better and meets certain operational benefits, but does one NEED it? Seems to me that Ford specs out the coolant (they could have used a lessor technology coolant than the Premium Gold, but they didn't... wonder why. With the various plastics and metals used... not using something that meets their specs could or will invite problems... at some point down the road.
I am not willing to risk it... but if others are... good luck to them.
Jeff
It will be going in my 94 Bronco as soon as UPS delivers it.I am about to order the coolant filter for it, too...at 30 bucks a gallon to the door I would like to preserve it as long as possible
As a side note, the manufacturer only knows best when it the decision will be on the side of profit. Just because it isn't used as OEM doesn't mean it is inferior (there are lots of products out there that are superior to OEM standards). Just because Ford didn't put a coolant filter on the truck doesn't mean that there shouldn't be one, and the same thing applies with many other things on the market.
Ford or any other manufacturer is going to choose the equipment that will get the job done sufficiently, the cheapest. It doesn't mean that it is the most efficient or longest lasting equipment, its just what they chose to use.
I had to get my Bronco from the dealer.Jeff, I ordered my coolant filter today and printed your instructions. Thanks for taking the time to post all that.
Russ
When your filter arrives, look at my instructions and those that come with the filter... it will make better sense. Took me a few readings and few "look twice, cut once" issues when installing... but when it was done... it worked!!!
Good luck,
Jeff
