302 Power
Old Aug 10, 2005 | 07:47 PM
Kev89's Avatar
Kev89
Angry 302 Power
Need more power from my 89 302 in my bronco. Already have an Edelbrock Intake, Edelbrock 650 Carb, Comp Cam, and Hooker headers. If anyone has a power increase idea, without pulling the motor, I would really appreciate it.
Thanks.......
Old Aug 11, 2005 | 07:44 AM
ronclark's Avatar
ronclark
Heads are your limiting factor.
1. A set of AFR heads or other after market heads would be best .
2. Port your own heads or get someone to port them is a cheaper alternative.
Old Aug 11, 2005 | 09:00 AM
garsten's Avatar
garsten
depending on how much lift your cam has, you could also go with bigger valves, E7 heads can be machined to 1.94/1.60. a complete set of good manley valve will cost $200 plus machine work. i hate to say this but if your ride does not get emission tested or inspection, remove the cats, they rob a bunch of power. free flowing muffler and 1/4'" larger diameter exhaust system. cheers, garsten
Old Aug 11, 2005 | 10:50 AM
rusty70f100's Avatar
rusty70f100
Well, I think nitrous oxide or a supercharger would be your best bet... See here. Then see here.
Like was said above, head porting can make a real difference.
Old Aug 12, 2005 | 10:50 PM
Kev89's Avatar
Kev89
Thanks for the info will try porting the cast heads. Thanks
