1978 - 1996 Big Bronco
belt diagram
Old Aug 10, 2005 | 05:26 PM
ctch88's Avatar
ctch88
belt diagram
Anyone know where I can find a serpintine belt diagram for my '90 351? It's just one belt, and the Hayne's manual only shows old style v-belts. Thanks.
Old Aug 10, 2005 | 05:49 PM
frozen bronco's Avatar
frozen bronco
Thumbs up belt guide
did you check on the front valance right by the hood latch. that's where i found mine after searching for approx 4 hours.
it's the same as a 302. i tried to attach a diagram but was unable.
Old Aug 10, 2005 | 08:54 PM
ctch88's Avatar
ctch88
Yes, I've looked for the sticker on the valence, hood, door pannel, I didn't get a manual with the truck either. I think I've figured it out though. The way I have it, the belt does an "S" around the water pump and crank pulleys. This way the fan rotates correctly and the V's and flat sides hit the pulleys correctly too.
Old Aug 11, 2005 | 12:35 AM
frozen bronco
belt direction
that sounds about right, if you have it ono wrong thaere's pretty much now way to get it on all the pullys. let's see if i can describe it
the only pulleys that have the belt going around them in a counter-clockswise direction are the Water pump and the auto-tensioner.
hope that helps.
Old Aug 11, 2005 | 12:41 AM
ctch88's Avatar
ctch88
Yep, that works. Thanks for the help. I can't believe I couldn't find a diagram through google/yahoo... It seems like that would be something in the Haynes manual or somewhere.
I'll post a pic in my gallery for future reference if your doing a search and found this thread.
B-Ryan 02
Aug 14, 2023 05:40 PM
Fitzgerald_welding
Oct 2, 2019 01:56 PM
beartracks
Aug 28, 2012 04:45 PM
upnorthman
1997 - 2003 F150
Nov 26, 2010 02:11 PM
mollikate
Jul 14, 2007 08:20 AM
