chugging diesel?
Old Aug 10, 2005 | 04:56 PM
Gary E's Avatar
Gary E
chugging diesel?
This has happened randomly on 3 seperat occasions in the last 6 months (8000 miles). I will be cruising down the road and all of the sudden the motor will Chug hard 2-3 times, it seems like more than just cutting out. its a 99 with alomost 200k miles. any ideas?
Old Aug 10, 2005 | 05:18 PM
Fire Rooster's Avatar
Fire Rooster
water in fuel, low oil, bad oil, cps, bad pedal sensor
Old Aug 10, 2005 | 05:27 PM
Gary E's Avatar
Gary E
Can I rule out water in fuel since I had just drained some fuel out of the fuel bowl? Just a quick shot out. The oil is up on the dipstick allright and its pretty new. Is this a pretty common symptom of the cps going bye bye? Will it someday leave me stranded or just get progressivly worse?
Old Aug 10, 2005 | 05:33 PM
Fire Rooster
all of them die out different, some have symptoms and some just die.
Old Aug 10, 2005 | 05:45 PM
Fat Diesel's Avatar
Fat Diesel
The CPS usually just quits. What you have sounds a lot like the "under valve cover" harness issue. Have you ever pulled the valve covers and installed the clips from Ford? What happens is the injector wire harness plug starts working itself loose from the valve cover electrical connector, inside the cover.
I'm not saying that is what it is, but that is what it could be. If it gets worse, like doing it all the time, then it's probably that connector.
On the other hand, you're truck has gone a long way and it's less likely on high milage trucks IMO. Good luck and let us know how it turns out.
Old Aug 13, 2005 | 04:28 PM
Gary E's Avatar
Gary E
Well It left me on the road today! What a comedy of errors. I popped the hood and got some white smoke, turns out the new heater bypass valve was leaking ontop of the back passenger side valve cover. and running down on the exhaust and steaming up. (there aren't any wires there that might of got wet and caused it is there?) So I drain the fuel bowl and try again, and no go. Cranks over great just no start.
So while waiting for my wife to come get me I decide to disconnect the batteries to reset the computer and I leave the key on and the fan and radio on to suck out an extra power. And when I reconnect the battery my cheapo alarm locks the doors with my key in the ignition , So I call my wife so she brings my spare alarm fob since I don't have spare keys (dumb) Finally my wife gets there and the spare fob won't work So we leave to where I was originally going and came back an hour later with a coat hanger and some wood to jam in the door opening and get into the truck and it starts back up and drives home no problem.
I guess I am going to get a new cps and try that since a bunch of you guys suggest having a spare anyway. We'll se where it takes us from there.
Old Aug 13, 2005 | 04:58 PM
fasthauler's Avatar
fasthauler
If you had my luck you would have left your cellphone inside of the truck and wouldn't been able to call your wife.
Old Aug 13, 2005 | 09:27 PM
thestroker97's Avatar
thestroker97
I would reallly be surprised if it isnt the cam shaft censor, PSD eat those like candy, kinda like the other breed (the goats, DODGE and there lift pumps).
