400 Trouble
Old Aug 13, 2005 | 08:13 PM
MBBFord's Avatar
MBBFord
The engine is a 79 same as the Bronco, I'm not sure about the timing chain, but I know I had a long block rebuilt about 70k miles ago, so the chain couldn't be in horable condition.
Old Aug 13, 2005 | 08:37 PM
Socketman's Avatar
Socketman
i think the key factor here is water and it only belongs in one place. so if the distributor is dry there may be a chance some got into the carb. once in the float bowl it will sit on the bottom and cause all kinds of havoc.If you truck ran fine before you washed the engine that would be the next place i looked.
Old Aug 13, 2005 | 08:41 PM
MBBFord's Avatar
MBBFord
I'm pretty sure the engine got some water, because when I took off the air filter the carb was a little wet. So would the water only be in the carb, or in the engine? If in the engine how well and safe at the same time would it be to turn the engine without spark pulgs?
Old Aug 13, 2005 | 08:43 PM
Socketman's Avatar
Socketman
its a little late for that. as you have attempted to start it. it may not have turned over for you because it was hydrauliced.
Old Aug 13, 2005 | 08:44 PM
danlee's Avatar
danlee
How much water could get into the motor from spraying it? A little water will not cause any long term problem. It would take a lot of water to cause a problem.
Start from the begining. Check the spark, and the timing, and the fuel, and the air.
Does it crank over easily?
If not remove the plugs and crank it. Does it crank now?
If it cranks OK, does it try to start?
Old Aug 13, 2005 | 08:55 PM
MBBFord's Avatar
MBBFord
I think some water go stuck in the air filter and sucked through into the engine, but the engine cranks over easy, but doesn't try to start. It cranks then some gas vapor or fumes shoots up form the carb and then the exhaust sounds like a little back fire.
Old Aug 13, 2005 | 09:28 PM
danlee's Avatar
danlee
That is timing/ignition or mixture.
Check your timing and firing order and your spark. Look into the throat of the carb with the engine off and pump the gas pedal. Look for a stream of fuel squirting into the carb.
Old Aug 18, 2005 | 09:43 PM
mattselland's Avatar
mattselland
I had a similar problem in the 400 in my 77 f-150. But in mine first it would turn over slow and not charge then after i got that fixed it started running bad about a month later. First it would turn over slow and wouldnt charge. I went through everything and ended up replacing the battery cables and it worked like new. Then about a month later the timing chain jumped a tooth (nobody ever accused these motors of having a great timing chain) and it would run really crappy and had no power. It could have been that these two things happend to you at the same time.
Old Aug 18, 2005 | 10:06 PM
MBBFord's Avatar
MBBFord
I'm going to check out the timing chain when I get a chance saturday, IF it is messed up, I think I'm going to go with a double roller timing chain, which would be much better than stock.
If you have any other Ideas, I'm open for comments.
Old Aug 24, 2005 | 10:23 AM
79F150400M's Avatar
79F150400M
I had similar problem as you. Would try to start while cranking, but let off the key and it would die. (With some backfire) Turned out to be my coil wire on the coil end. It was corroded bad. I had tried new dizzy, cap rotor, new plugs (have Taylor wires), and was thinkin timing chain when i decided to check coil wire and viola!!! Give it a try if you haven't already. Just me .02...
Old Aug 24, 2005 | 06:23 PM
MBBFord's Avatar
MBBFord
I tryed putting starter fluid everywhere, coil, distributor, ignition module, down the carb, and then I tryed to start it and it did. It ran like crap, so I turned it off, figuring it was the timing chain. I rechecked my spark plug wires and I had 2 mixed up and I put them like they were suposed to be and I started it and it ran like a champ.
Thanks for all the help guys, I really appreciate it.
Old Aug 27, 2005 | 11:24 PM
roger dowty's Avatar
roger dowty
Is there an update on this? Curious!
Old Aug 27, 2005 | 11:27 PM
  #28
MBBFord's Avatar
MBBFord
What do you meen by update, I said it started, but are you asking how it's running still?
Old Aug 27, 2005 | 11:43 PM
  #29
kopfenjager's Avatar
kopfenjager
Yeah that last post kind-a cleared it up, but yeah hows it running?
Old Aug 27, 2005 | 11:44 PM
  #30
roger dowty
sorry- I didn't see the updated responses. I was going to ask if you had messed with the wires when cleaning it- I did that once and had the same results.
