frame swap, 94 150
Old Aug 9, 2005 | 03:15 PM
etpnfc's Avatar
etpnfc
frame swap, 94 150
I have a 94 f150 short bed, single cab 4x4, and recently noticed a crack in the frame. The local frame shop told me to just buy a new frame and switch everything over. What year model frames would swap if a 94' can't be found? Would it be worthwile to swap for 3/4 ton ?Should a novice attempt this swap or is it a job for a PRO?
Old Aug 9, 2005 | 04:21 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
