ID plate info please..
Old Aug 9, 2005 | 03:02 PM
packrat56's Avatar
packrat56
I have a 56, the plate reads:
F10 D6R - 15488
5000 lb 110 wb 120 hp @ 3900rpm
4 SYN 3.92 GE tan 1 L 528
I know the lb, wb, hp.. what are the other numbers?
Thanks!
Old Aug 9, 2005 | 08:27 PM
Earl's Avatar
Earl
F10 D6R - 15488
Thanks!
There is a VIN decoder here for future reference http://www.clubfte.com/users/earl/Re..._Material.html.
Your VIN decodes as:
F10 = F-100 Series Truck
D = 223 CID six cylinder engine
6 = year of decade in which truck was produced (1956)
R = Richmond Assembly Plant
15488 = 5488th unit produce in 1956 (the consecutive unit numbers start at 10001)
The other numbers on your rating plate are:
4 SYN = 4-speed synchromesh transmission
3.92 = rear axle ratio of 3.92:1
GE = Paint codes for a two-tone Meadow Mist Green and Colonial White
tan1L528 = production code
tan = ???
1L = Built on day 1 of November, 1956
528 = ??? (should be a two-digit district code)
Hope this helps!
Old Aug 9, 2005 | 09:53 PM
packrat56's Avatar
packrat56
Thanks!
Old Jan 29, 2006 | 06:39 PM
wayne486's Avatar
wayne486
Think i found your jack.Lookat the us patents at uspto.gov igot three patent numbers on mine,this site shows specs and origanal drawings and tells all you want to know about the jack.
Old Jan 29, 2006 | 06:42 PM
wayne486's Avatar
wayne486
oh ,my patent#s are 1424962 , 1638791 , 1648036 ,ihave the 1638791
Old Jan 29, 2006 | 08:13 PM
packrat56's Avatar
packrat56
Cool, Ill check it out!
