left hand drill bits
Old Jul 5, 2001 | 10:03 AM
tvh2003's Avatar
tvh2003
does anyone know how to use and sharpen left hand drill bits?
Old Jul 5, 2001 | 10:14 AM
whomrig's Avatar
whomrig
I have never seen left-hand drill bits.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 5, 2001 | 10:37 AM
mefsh's Avatar
mefsh
I have used a lot of left handed drill bits. Sharpen them like right handed ones except the cut is different direction. Mainly left handed bits are used to remove right hand threaded bots. Not much different just counter punch a hole and then drill with it.
Old Jul 5, 2001 | 01:31 PM
deere81's Avatar
deere81
I've used left hand drill bits and had good luck removing broken bolts.
Old Jul 5, 2001 | 03:08 PM
Raul's Avatar
Raul
Where would one buy these drill bits? Normal hardware stores (e.g., Home Depot, Lowes) would not carry these would they? Or does one have to order them on-line?
TIA
Raul
w/ 81 F-100, I6, SROD, Carter 1V non-feedback carb, no A/C, no PS, no PB, but it gets me where I need to go
Old Jul 5, 2001 | 04:05 PM
tvh2003's Avatar
tvh2003
We bought ours at snapon.com
That would be the best place to get them
Old Jul 5, 2001 | 05:09 PM
mefsh's Avatar
mefsh
I believe you can get them at Sears as well.
Old Jul 5, 2001 | 07:02 PM
whomrig's Avatar
whomrig
Just goes to show you learn something new all the time....
Wayne 60 F-350
e-mail
Old Jul 5, 2001 | 07:04 PM
Rosati's Avatar
Rosati
Just so somebody doesn't think your talking about these bits like they are left handed crescent wrenches, or skyhooks, I thought I'd help to clarify the obvious.
"Left handed" referes to the fluting of a drill bit opposite those commonly found at the hardware store. They are note used strictly by those lefties. They are note for drilling left sided holes or holes through the left side.
Reversed drill bits are for drilling through rusted/stuck fasteners in the hopes that if you cut fast enough and hard enough, your bit will bite into the fastener and unscrew it during the drilling process. These are also refered easy-outs but are not true easy-outs.
I find these bits work very well on smaller fasteners rather than large bolts. If a bolt (say a 3/8 shank) or larger is stuck, the chances of a reverse bit getting it out before drilling all the way through are very slim.
IMHO.....Krosati
Old Jul 10, 2001 | 12:22 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Old Jul 12, 2001 | 01:58 AM
MEPHISTO_XES's Avatar
MEPHISTO_XES
An ACE Hardware store had wronghanded(left) bits. The bits were
in the same area as the tap/die/extractor section.
Been awhile since I heard the skyhook mentioned.
Garett
Old Jul 12, 2001 | 06:13 AM
TallPaul's Avatar
TallPaul
Well my Sears drill is so old that it has a metal case and only runs in one direction. Guess I can't use it with left handed drills. But what a drill. Gotta be at least 40 years old, but that thing just won't quit.
Old Jul 12, 2001 | 07:38 AM
Raul's Avatar
Raul
You mean there was a time when reversible drills did not exist? That's gotta be old.
Raul
Old Apr 1, 2008 | 04:09 AM
four-sixty-power's Avatar
four-sixty-power
Haven't seen anyone mention these in a while (check the dates of the posts)
Old Apr 1, 2008 | 06:31 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Wow!!!!!
You had to knock the cobwebs off of that thread!!!!!
I too, had never heard of left-hand drill bits, until I stumbled onto this.
(Hmmmmmmmmmmmmmmm. . . ya know, it is April Fools Day!)
