Tip:
Old Aug 9, 2005 | 10:49 AM
fisoman's Avatar
fisoman
Wink Tip:
Have you ever washed and ragged your '04/'05 FX4 and had those virtually useless outside bed hooks leak water down the side of the bed? And even a day later take alittle cruise in your clean machine and have water streaks down the side. Well fear not, there is a cure. Carefully take the hooks off, take special attention how they go back on, and take a rat tail file and cut a grove in the bottom center of the plastic backing plate for the hook and reinstall. This allows the cavitity behind the hook to drain and viola, no more streaking.
Old Aug 9, 2005 | 11:35 AM
chains's Avatar
chains
That's a great suggestion! I have a Flareside and have experienced the same issues as you. It sounds like a quick and simple solution. Any particular precautions as far as removal or is it straight forward? I can't wait until the weekend to give it a try. Thanks for sharing this with the group.
Old Aug 9, 2005 | 11:44 AM
fisoman's Avatar
fisoman
Not really, just the usual of no losing anything and getting all the gizzmos straight and bolt her back down.
