Where can I check the 4X4 details?
I've read the low range ratio listed as either 2.56:1 or 2.65:1. The front diff is a Ford 8.8 high pinion diff. Not sure if it is 28 or 31 spline axles though? Rear diff on most is the semi float 9.75", I've seen listed as both 34 spline and 31 spline axles? tansfer case is a Borg warner part time case, not sure what model number though. I checked mine and couldn't find and ID tag on it.
About the front end, does it have hubs, like pulse vacuum hubs etc, or does it turn all the time. I tried to turn the front axle half shafts and wasn't able to turn them by hand, which would seem to suggest that there are no hubs. But I read that the hubs unlock with vacuum and so when the truck is off will lock???
Originally Posted by ytc
So in case of one side slipping, does the rear diff use some clutch to disconnect power to that wheel like jeep does, or just lock two rear wheels up?
Wheelerfreak, you can read this message.
https://www.ford-trucks.com/forums/s...d.php?t=400505
