Edelbrock again?
Old Aug 9, 2005 | 12:36 AM
imlowr2's Avatar
imlowr2
Edelbrock again?
I'm hoping this is simple. My carb has a slight hesitation when making a turn. A friend of mine told me to adjust the linkage at the accelerate pump on my Edelbrock 1405 Carb. There are three positions. What position is it suppose to be in? It's currently in the middle.
Old Aug 9, 2005 | 06:59 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
If the carburetor is like most vehicles middle is the default setting for the accelerator pump. Look at the linkage whichever direction moves the linkage to give you a longer stroke is setting it run run richer when you accelerate. Moving it the other direction produces a shorter stroke which leans it out a bit on acceleration.
Old Aug 9, 2005 | 08:29 AM
SteV8e's Avatar
SteV8e
The fact that you are fuel starved during a turn leads me to think that your float is set too low. You need more fuel in the bowl so that the gravity of the turn won't pull all the fuel up against the side of the bowl.
Old Aug 9, 2005 | 08:39 AM
Spaznaut's Avatar
Spaznaut
Yeah it has to do with the floats not the accelerator pump. Let us know how it goes.
Old Aug 9, 2005 | 09:59 AM
imlowr2's Avatar
imlowr2
A friend of mine told me it could be either one but leaned toward the float level also. I recently took the top of the carb apart to clean out some dirt that was inside, I checked the floats and the measurement was fine? I may have to pull it apart again and check. I'll let you guys know. Thanks for the input. Ed.
Old Aug 9, 2005 | 01:40 PM
frigerator's Avatar
frigerator
I would also look at flushing the gas tank, putting an In-line fuel filter on and get my gas somewhere else if you've got dirt in the carb.
GamerGirlAlice
Jan 17, 2013 11:15 PM
atomicjoe23
Sep 6, 2010 02:40 PM
firegod33
13
Apr 16, 2008 04:19 PM
AKMac
Jun 1, 2004 07:05 AM
cseay1
Oct 18, 2002 04:28 PM
