which flexplate should I use?
Old Oct 16, 2002 | 05:13 PM
Torque1st's Avatar
Torque1st
Posting Legend
Old Oct 17, 2002 | 09:15 AM
cjben's Avatar
cjben
Ok, I am swapping a 1986 351w in my 1978 f100 where a 302 used to be. which flexplate should I use the 351w one, or the 302 one, or are they balanced the same? thanks, Ben
Old Oct 17, 2002 | 09:21 AM
LxMan1's Avatar
LxMan1
They should be the same. I would use the one that came on the engine that you are installing.
Old Oct 17, 2002 | 07:39 PM
joetee10's Avatar
joetee10
You should not use the 302 flexplate since the early model 302 (pre 82)uses a 28oz balance, you need a flexplate for a 50oz balance 351 with the appropriate number of teeth for your application. Go by any transmission shop and they should be able to recommend the correct one, or you could call Summit Racing 1-800-230-3030, and they could help.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
