95 f 150 camber problem
Old Aug 8, 2005 | 08:21 PM
wellys's Avatar
wellys
I have a 95 f 150 which I recently added a 4" lift to the rear axle and put all new shocks and coil springs in the front for a 4" lift and the radius arm drop brackets and cross member The rims and tyres were 35x15x12.5 BFGoodridge mud terrain on american racing rims. But then I discovered a camber problem with the front wheels laying out at the top. Any sugestions as to how to remidy this the cheapest way possible. Thanks any help would be greatly appreicated,
Wellys
Old Aug 8, 2005 | 08:45 PM
MustangGT221's Avatar
MustangGT221
There are camber adjustment nuts on the top ball joints. The stock ones adjust for 1 degree pos/neg. There are also aftermarket ones that do 2 and 3 degrees.
Old Aug 8, 2005 | 09:00 PM
wellys's Avatar
wellys
Thanks alot buddy any info as to where to get them thanks again
Old Aug 8, 2005 | 09:44 PM
handyman43358's Avatar
handyman43358
heyyyy could that be why the tires on my truck still lean out a little although i put new balljoints in?
Old Aug 9, 2005 | 03:42 PM
alz's Avatar
alz
Jeff's Bronco Graveyard has them.
Old Aug 9, 2005 | 08:19 PM
MustangGT221
Yup, you need an alignment after doing ball joints.
I believe superlift or skyjacker also have them.
Old Aug 9, 2005 | 09:35 PM
handyman43358
Wait lemme rephrase that. The truck drives straight as can be. No pulling either way. It just looks like the bottom of the tires are pushed out still....like this when u look at it from the front / \..... but not as much as they were before.
Old Aug 9, 2005 | 10:52 PM
MustangGT221
Doesn't matter what the truck drives like, sometimes they can drive perfectly straight because the toe is correct, but wear tires cause the camber is wrong. If you install ball joints you need to have it re-aligned.
Old Aug 11, 2005 | 04:47 PM
handyman43358
I'll take ya up on that advice cause I really do need to get it aligned. Thanx man.
Old Aug 11, 2005 | 05:33 PM
MustangGT221
Also, anytime the height of the vehicle is changed, either up or down, it needs an alignment.
I put my lift kit on and my alignment was still ok, i wanted to wait 5-6 months for the springs to settle anyway, then i had ball joint replacement coming, and then the truck was stored for a new engine. I havn't ever gotten an alignment on my truck, but now that i put the 393/zf in, I lost about an inch in my front suspension, and it's wandering all over the place. Time to go for me too
Old Aug 11, 2005 | 06:33 PM
MEANBLUOVL's Avatar
MEANBLUOVL
Napa also sells the adjustible bushings.
Old Aug 11, 2005 | 08:02 PM
wellys's Avatar
wellys
I Bought a centre hinge drop bracket, the amount of camber couldnt be rightafied with those ball joints, thanks anyway
Old Aug 11, 2005 | 08:11 PM
ceetwarrior's Avatar
ceetwarrior
When I put the 2" taller coils and 31"s on my f150 I had to get bigger alignment cams. I think they are 2-3 degree as mustangGT221 said vs. the 1 stock. My wheels look like: \ / from the front view. I had it realigned 20,000 ago when I put it on and they said the springs would settle but its still off a little bit, even with the new cams. So I just keep my tires rotated every 10,000 and all seems fine.
I see they sell those I beam drop brackets in JCWhitney, I wonder if those are any good vs. the ball joint alignment cams... ?
Old Aug 12, 2005 | 04:41 PM
wellys's Avatar
wellys
I will let you know Im putting mine on tomorrow morning have BFGoodridge 35x15x12.5 tires and a 4" lift this thing looks mean, just the right amount of lift
Old Aug 14, 2005 | 03:57 PM
jhnhardee's Avatar
jhnhardee
i did a rancho 4" and it took 3 deg shims and it went right back to perfect, i used the superlift adjustable shims, and took it to get aligned, the kit i got had drop brackets,extended radius arms, add a leafs, with 35" meats and 4" you might have to do some fender trim'm if you run 'em at full stuff alot they may rub a little
