My local salvage yard wanted $35.00 but never had them in stock.
I ended up getting it off Ebay for $10.00. Make sure you get the
right one, I think the height of the jack changes for some models.
i just used a 48" Hilift bumper jack, its good for jacking, but it can also be used as a come-a-long and as a clamp too. its great for off-road use and lifted or HD trucks.
i use a 5 ton bottle jack. if you go with a stock jack, make sure you get one from a F250, or F350. the F150 jack will not go high enough to get the inflated tire back on after you get the flat off. been there ,found out the hard way.
