Sponsored by: Real Truck
sd ?
Old Aug 9, 2005 | 09:55 PM
captchas's Avatar
captchas
Guest
my biggest problem is behind my garage is 500 gals of propane. and next door is another 500. that ='s one very big BOOM
krewat's Avatar
krewat
FTE Leadership Emeritus
They have (for years) used the brake light switch to disable the cruise control.
I take it that that's a safety problem, as in, if the switch goes bad, you can't turn off the cruise with the brake, and Ford's liable.
Imagine the accountants doing the cost-analysis of both
Old Aug 9, 2005 | 10:03 PM
n578md's Avatar
n578md
OK, sure but what if the master-cylinder switch goes bad and the truck catches fire... Which is worse? I think it could happen at anytime, while driving or while that truck is parked and shut-off since there is power to that switch at all times. If the brake light switch fails and the cruise is on, I can 1) press the clutch (the clutch-interlock switch also disconnects the cruise.), 2) take it out of gear or 3)turn the key off, but if that damned thing burns and catches the truck on fire while I'm in it? I'd rather have a BOO-switch with a small chance of failure than the fire-hazzard that's currently in use.
Old Aug 9, 2005 | 10:07 PM
raybo54's Avatar
raybo54
captchas,
Don't know for sure but there is a recall on the cruise switch's because of fire hazard!!
My nephew informed me last month when I was in N.C. Reading your post reminds me to take a look mat mine tomorrow.
Thanks for bringing it up.
Raybo 54
'01SD V-10/lwb/Xcab/auto
'91 F250 7.3/lwb,deceased
'77 F150 4X4/swb/ inline bad ta tha bone 6, deceased
Old Aug 9, 2005 | 10:30 PM
krewat's Avatar
krewat
And so around, and around, we go, sorry, the brake light switch didn't deactivate your cruise-control so you hit the guard-rail.
Gee, now you say that our re-engineered cutoff burns the truck down to the ground? Well, that's better than running off a cliff, right?
I'm being sarcastic, I love Fords, better engineered than anything else, but sometimes, I don't know...
Old Aug 9, 2005 | 10:50 PM
88svt's Avatar
88svt
Just a note 578, (2) take it out of gear, does not turn off the cruise. When I drive easy, as I mostly do, I usually shift without the clutch. One day I was in cruise and coming down a hill to an exit ramp so I just bumped it out of gear. I was sure shocked to see as I slowed down the engine raced WAY up. Your truck does not know when your out of gear if you don't push in the clutch!!
Old Aug 9, 2005 | 10:53 PM
n578md's Avatar
n578md
The point wasn't that taking it out of gear turns off the cruise control, the point is that the truck will no longer receive power to the wheels allowing you to stop. (And yes, my truck does the same thing... the stupid thing will go to 5500 rpms and keep bumping into the rev-limiter ad-infinitum.)
Old Aug 10, 2005 | 12:26 PM
mwpierson's Avatar
mwpierson
There's always the CC OFF switch. I'd think that would disengage cruise if the brake light switch was to fail.
Mike
SD Dually
New Member Introductions
Dec 10, 2013 03:50 PM
Keanen
Nov 21, 2008 12:02 AM
DCH614
Mar 2, 2006 05:59 PM
buffy
Jun 21, 2001 05:26 PM
CW
Jun 4, 2000 01:56 PM
