rear gears
Old Apr 30, 2002 | 01:46 PM
79crazee's Avatar
79crazee
rear gears
Old Oct 17, 2002 | 04:40 PM
oft's Avatar
oft
rear gears
Hello all,
I have a 2 wheel drive 78 that originally had the I-6 with a 3 on the tree standard trans. Anyone know what gears would be in the rear? I have since changed the 6 out for a 351W and I am wondering if I should do anything to the rear.
Jayson
78 F100
93 5.0 GT
96 Taurus Wagon
Die Hard Ford Fan.
Old Oct 17, 2002 | 04:43 PM
mudder trucker's Avatar
mudder trucker
rear gears
if you leave the vin# some one will have an answer. mudder trucker.
Old Oct 17, 2002 | 04:46 PM
oft's Avatar
oft
rear gears
OK,
Here it is,
F10BCAG9391
Any other info from the vin would be great as well.
Jayson
Old Oct 17, 2002 | 07:30 PM
73Highboy's Avatar
73Highboy
rear gears
Usually those trucks come with low 3.xx gears. pull off your rear cover, and there should be three sets of #s under were the pan bolts on. first two are two digit #s, those are how many gears are on the pinion and ring. the pinion is your smaller #, ring is bigger. divide your ring # by pinion at that will give you your ratio. I'm sure you shouldnt have to change it, but if you want more go off the line, go a little lower, but dont go too low, so you have some top end.
Old Oct 17, 2002 | 08:27 PM
oft's Avatar
oft
rear gears
Well, thanks 4 the advice but I was hoping I wouldn't have to open up the rear diff. Don't need 2 know that bad!
Jayson
Old Oct 17, 2002 | 09:34 PM
tetraruby's Avatar
tetraruby
rear gears
79F100 that had a six behind it...you most likely have a nine in the rear. Good luck trying to get the "cover" off. Check for a metal tag that usually is on one of the third member bolts. I'm sure it'll be grimey...post the numbers exactly how they appear the tag. You could also try raising the rear end and counting the number of driveshaft rotations for each tire rotation...beats tearing into the rearend.
Old Oct 17, 2002 | 09:59 PM
oft's Avatar
oft
rear gears
I'll give that a shot. I am so not pulling the cover!
Jayson
Old Oct 17, 2002 | 10:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
rear gears
Jayson, the reason they said good luck with the cover is that a 9" rear axle does not have a cover, the whole diff assy (pig) unbolts from the front of the axle assy. Most of the time the diff ID tag is on the passenger side under one of the bolts at about the 8 o-clock position. If you have a door tag there are numbers on it that will identify the axle assy also.
Old Oct 18, 2002 | 09:00 PM
oft's Avatar
oft
rear gears
Don't I feel like a moron. Guess i should have looked b4 I posted.
Jayson
78 Ford F100, 351W
93 5.0 GT
92 Taurus Wagon
die hard ford fan.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
