86 Ranger will not start after problem
Old Aug 8, 2005 | 12:52 PM
Bearcloud's Avatar
Bearcloud
Unhappy 86 Ranger will not start after problem
I was going down I-95 at about 70 when the truck start hickuping , revving up and then back down and oil pressure began to climb. Pulled over and shut it off. Now will not start or even turn over. Only clicks. When we tried the push pop clutch method of starting smelled of Flooded Gas.
Any ideas what this could be and what to look for?
Specs:
1986 Ford Ranger
Fuel injection
2.0 engine *I think* might be 2.1 or something like that.
Old Aug 8, 2005 | 01:08 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 8, 2005 | 01:25 PM
87 XLT's Avatar
87 XLT
Dead battery? Connect your voltmeter to the battery a fully charged battery will read about 12.7 volts
Old Aug 9, 2005 | 01:16 AM
Bearcloud's Avatar
Bearcloud
not battery
Not the battery. Lights work and even tried charging thats not it. But I will check that out, thanks for the suggestion.
Old Aug 9, 2005 | 12:18 PM
87 XLT's Avatar
87 XLT
In that case, it might be getting too much fuel or no spark. If you hear the fuel pump when you turn the key to run try removing the vacuum hose from the fuel pressure regulator it should be dry.
Check for spark, pull codes and check fuel pressure & see what you come up with.
Edit, Since it wont even crank are the battery cables in good shape & clean & tight?
Old Aug 9, 2005 | 05:24 PM
jbaschuk's Avatar
jbaschuk
check to see if you might have a loose ground wire. check the main groung first and go from there..... ive seen this problem before and it turned out to be a bad ground..... good luck
Old Aug 9, 2005 | 08:30 PM
hunter1988's Avatar
hunter1988
I have the same truck(2.9 V6 automatic), The battery is charged, efi pump runs, then when I try to start it it used to click.. put new solenoid in, no click... Engine wont turn.. I havent run it all winter.. had in in the garage fixing the tranny...It doesnt even turn over the starter(which was tested and is good...)
Old Aug 14, 2005 | 12:32 AM
Bearcloud's Avatar
Bearcloud
Smile Fixed
Ok thanks for the help folks. Got it fixed. Here's what the problem was.
Trash in the fuel system. AND a loose ground wire on the started. Trashed seemes to be out after revving it up , going to put some stuff in it to further help it. AND tightened the ground on the starter.
Thanks again for all the help.
Bearcloud
Old Aug 14, 2005 | 11:54 PM
el conquistador's Avatar
el conquistador
be sure to change the fuel filter
