Heater not getting hot?
Old Oct 18, 2002 | 05:23 AM
bentkey's Avatar
bentkey
Old Oct 18, 2002 | 07:50 AM
BigDaddy29178's Avatar
BigDaddy29178
This morning was in the 40's and I finally had to use my heater and it didn't get hot. It has always worked has something gone bad? I could use a little info on this matter. I can't go without my heater.
Thanks
:-X12
Old Oct 18, 2002 | 08:22 AM
mudmnky's Avatar
mudmnky
Did you check to see if the bypass valve was working properly. The cable on mine was gummed up and the butterfly wouldn't open.
Old Oct 18, 2002 | 10:21 AM
theonlybull's Avatar
theonlybull
might need a flush,,, they can gum up over the summer of not being used
Old Oct 18, 2002 | 10:57 AM
Ken2600's Avatar
Ken2600
Sometimes even a thermostat gone bad will cause the heater to not heat up as hot or as quick.
Old Oct 18, 2002 | 12:11 PM
todd_adams2001's Avatar
todd_adams2001
Are getting POWER to the fan aren't ya?
Old Oct 18, 2002 | 01:22 PM
BigDaddy29178
Yes I have power to the fan shes blowing like a champ. Where is the bypass valve? Is it the on one of the heater hoses or is it the one on top of the casing for the fan?
Thanks
Keith
Old Oct 18, 2002 | 02:05 PM
bigf150's Avatar
bigf150
I would do a flush and fill and then if it still doesnt work check everything that everyone else suggested and mabye the heater core. Good luck!
Old Oct 18, 2002 | 10:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can also get leaves and junk down into the heater that will block up the works.
