hot rod black
Old Aug 7, 2005 | 08:56 PM
f-4x4's Avatar
f-4x4
hot rod black
ive got a 79 4x4 f-150 that i would like to paint a hot rod black. sort of flat and a black or a real real real real dark grey. whar would be the best methode to use and i needs to be real tuff. any input would help.
Old Aug 7, 2005 | 11:30 PM
minishtr's Avatar
minishtr
Have you thought about military flat black cammo paint? It's suppost to be tuff stuff.
Old Aug 8, 2005 | 05:37 PM
JeffWal's Avatar
JeffWal
i would do hok black base the hok uc 35 clear with flattener in it. check out their web page for more info on the flatener. but it dulls the clear to give that primer look... but with clear coat protection.
jeff
Old Aug 8, 2005 | 09:13 PM
f-4x4's Avatar
f-4x4
is hok house of kolor. and what primer would do good under the paint
Old Aug 11, 2005 | 08:00 PM
JeffWal's Avatar
JeffWal
yes hok is house of kolor... i would use balck primer then you coverage is quicker
jeff
Old Aug 14, 2005 | 06:05 PM
f-4x4's Avatar
f-4x4
any one have any pictures of a truck done like this
Old Aug 16, 2005 | 09:29 PM
77460ford's Avatar
77460ford
You mean like this?
Old Aug 18, 2005 | 03:38 PM
f-4x4's Avatar
f-4x4
Originally Posted by 77460ford
You mean like this?
hell yeah i mean like this one! what paint did you use, is it primer black witha flatend clear. come on more detail please
Old Aug 18, 2005 | 07:51 PM
77460ford's Avatar
77460ford
This is actually the second attempt. First we shot it in base and killed the clear. It was really dull, almost a black grey but looked good. The only problem was that it took a while to dry and we found finger prints (could have been our fault with the mixture). Instead of playing around we sanded and shot with one step and it came out well. I'll have to ask the painter on the products but almost any paint supplier will give you the right recipe. It's stood up well over time, a quick wash and you're good to go. I shot the gloss black flames to see how it looked, they are subtle depending on the light. With those I cheated and bought a stencil that has adhesive. Stick it on, pull off the flame, shot and remove the stencil. They offered any size and lots of different designs. Hope that helps.
John.
Old Aug 18, 2005 | 11:46 PM
Fordtuff4x4's Avatar
Fordtuff4x4
grab som primer put some clear in it
Old Aug 25, 2005 | 01:45 AM
tankglh21's Avatar
tankglh21
i had sanded my truck down and didnt want it to get rusty and i had some cans of black bbq paint laying around so i sprayed that on there just to cover it up and it didnt turn on that bad. but i am going to spray it real flat black here as soon as i get my new bed on. but here is a picture if anyone wants to see
Old Aug 25, 2005 | 07:13 PM
RocketScience's Avatar
RocketScience
f-4x4,
The technique you are referencing actually has an unofficial classification in the Hot Rod world called "Rat Rod", or primered street rod.
The popularity of this classification has boosted sales of PPG's product line of their epoxy primer/sealer called "DP". This product will net you the results you desire. It is available in many colors. Here is the line-up:
DP 40 (light gray)
DP 48 (white)
DP 50 (gray)
DP 60 (light blue)
Dp 74 (red)
DP 90 (black)
Old Aug 29, 2005 | 10:28 PM
f-4x4's Avatar
f-4x4
Originally Posted by RocketScience
f-4x4,
DP 40 (light gray)
DP 48 (white)
DP 50 (gray)
DP 60 (light blue)
Dp 74 (red)
DP 90 (black)
are those primer or is that a one stage paint. thanks by the way
Old Aug 30, 2005 | 01:04 AM
RocketScience
You're welcome!
To answer your question, they are primers. But a more precisely, they are epoxy primer sealers.
