oil leak?
Old Aug 7, 2005 | 08:00 PM
wresleu's Avatar
wresleu
oil leak?
My 96 3.0/automatic/4x4 w/140,000miles on the ticker has developed an oil leak. A service tech told me it was probably the oil pressure sending unit, seeing that is where the leak seems to be originating from. Is this a hard or tough fix? There isn't much info in the chilton's manual. Should I replace with OEM part or is there an aftermarked that will perform as well or better? Anyone done this recently that can point out some troubles I may have? Thanks....in advance.
Addl note...it even drips when sitting in the garage...leaves an oil stain. Not a huge amount, but noticeable. I don't drive the old girl much anymore, so just want to keep her in service as needed.
Old Aug 8, 2005 | 06:14 AM
Bob Ayers's Avatar
Bob Ayers
The oil pressure sending unit is screwed into the block, just behind the head on the passenger's side. It can be reached from the top, but I found it was easier to jack the passenger's side up, and reach it through the inner fender liner......Good luck!!
Old Aug 8, 2005 | 06:46 PM
wresleu's Avatar
wresleu
OK I'll look for it this weekend. Any tips? Any mods I should make to it while i'm doing it?
1998Ranger25L153CID
Jan 6, 2015 01:51 AM
yfz 450
Jan 4, 2014 06:01 PM
solaratomic
Jul 25, 2010 02:56 PM
Al Mort
Dec 25, 2006 10:10 PM
95mazdab2300
Jan 7, 2004 05:21 PM
