Vw Jetta Diesel, Good Or Bad?
You can't eliminate the egr easily, but you can reduce it to almost nothing through programming (vagcom) for pre-PD motors anyway. Adding a better filter to the CCV (to filter oil out of the fumes) is another option. When the ULSD fuel is introduced this will greatly alleviate the problem. VW considers the soot a non issue until it reaches 3/8" thick.
As far as turbocharged motors go the tdi's turbo is pretty sturdy as I understand it. I've read of several people being told by a dealer that they failed, and it ended up being only a hose after getting a 2nd opinion. Surge can be a problem on modified cars (a whole topic itself).
I'd recommend going with an 03' or earlier (non PD) for various reasons. Mostly the egr issues haven't been completely solved and the new injection setup kinda worries me. That and I'm just resistant to change. They seem to be doing fine and have already been proven overseas for several years. Anyone considering one go read up at TDIclub.
Besides the TB (not unique to the TDI, but it is expensive to pay someone to do it) and soot (solved) where is all this EXTRA maintenance I hear about on the non-PD engines? Is it the 10K mile oil changes? Never had a drop of water come out of the seperator, no plugs/wires. I do use fuel additives, but it's not required. fuel filters cost a little more and getting to the oil drain plug is a pain (solutions for this too). Where it gets expensive is if you aren't a DIYer. I consider these enthusiasts cars, if you don't work on your own cars (and aren't well off) and don't feel like researching them, it might not be for you. Heck, I wish there was more maintenance to do.
Mines been basically perfect (had some small work done before I got it). I do have to admit though, I wouldn't have bought a vw if it wasn't a diesel.
/oh yeah, careful with the oil pan (hangs low) or get the european skid plate.
If your going to buy VW. like some one else posted Buy it Pre 95 or some thing like that. the newer cars have some horrible designs. My Ex had a 98 Beetle and everything was a problem. the powerwindows use wires to hoist the windows up and down. problem is the wires bind up and your window pretty much fall out. It was covered by the dealer though and her warranty was over. if you buy VW diesel is the way.
DemonRace6
1983 - 2012 Ranger & B-Series
15
06-09-2015 10:36 AM
Robert6401
12-03-2011 11:09 AM
njxlt
1997-2006 Expedition & Navigator
16
12-25-2007 06:52 PM
JimmyRC86F150
General Automotive Discussion
15
12-23-2005 06:36 PM
