Aerostar Ford Aerostar
cruise control....
Old Aug 7, 2005 | 10:41 AM
NeonAerostar's Avatar
NeonAerostar
cruise control....
I've had my 93 Aerostar XLT for 2 1/2 years now and the cruise has never worked. I'm tackling this now because I have to drive long distances now. The common problem that I can see from reading other postings is the clockspring. The problem that I'm having is I get no codes for the airbag, the horn has always worked.Could the clockspring still be the problem? I've been told that it could be the contacts in the switch because its a carbon to copper ring system. I would appreciate any help.
Old Aug 7, 2005 | 12:36 PM
cookkd's Avatar
cookkd
Have you checked the easy stuff first? My problem was a leak in the vacuum hose at the Cruise Control unit under the hood. Its kinda hidden down behind the battery and master cylinder......just a thought.
Old Aug 7, 2005 | 12:41 PM
NeonAerostar
thanks..replaced that unit with a take off from salvage yard this am and the vacuum lines in real good shape...
Old Aug 7, 2005 | 07:56 PM
DaveMac2Vans's Avatar
DaveMac2Vans
I have the 3-2 blink of the air bag light in my 94 XLT, but as horn and cruise work fine, I have learned to live with the light. Some of the fellows on here are of the opinion that there may be a connector issue in the steering column. I have other fish to fry, so the light continues to blink.
Old Aug 7, 2005 | 08:38 PM
Gary B's Avatar
Gary B
could be clockspring but check for brake lights first. also vacuum break adjustment. (switch on brake pedal with vacuum line to it).
Old Aug 7, 2005 | 09:37 PM
NeonAerostar
Got brake lights and the vacuum brake switch is working,i.e. adjusted properly...how could I tell if the vac switch is bad? Maybe if I remove the switch and plug the line and see if cc works then?
Old Aug 7, 2005 | 09:44 PM
xuzme720's Avatar
xuzme720
you haven't by any chance swapped the incandecent brake bulbs for the led style?
did that to mine and wondered for weeks why the CC wasn't working...then on a fluke tried the old bulbs and PRESTO...CC working fine
Gary
Old Aug 7, 2005 | 09:46 PM
NeonAerostar
no..standard bulbs in the tail....hasn't worked since I bought it 2 1/2 yrs ago. Driving long highway miles now so want see if I can fix it.
Old Aug 7, 2005 | 09:50 PM
xuzme720's Avatar
xuzme720
sorry, other than the bulbs mine hasn't acted up at all, so I haven't really had to try much else. hopefully someone will be along shortly with a better answer
Gary
