Help What Transmisson?
Old Aug 7, 2005 | 07:47 AM
lmhans4440's Avatar
lmhans4440
I am looking at buying a 1978 F-150 with a 300 (4.9) and the guy said it was a manual transmission with Reverse over twords the steering wheel and up. What kind of transmition is this?
Old Aug 7, 2005 | 07:57 AM
n9lhm's Avatar
n9lhm
sounds like a T18.
Old Aug 7, 2005 | 08:10 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Imhans4440, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 7, 2005 | 08:37 AM
lmhans4440's Avatar
lmhans4440
thanks n9lhm, is the T-18 a four speed or an overdrive? also are they very durable? Thanks.
Old Aug 7, 2005 | 09:32 AM
MBBFord's Avatar
MBBFord
I think they are just a 3 speed with no over drive, but I could be wrong.
1st gear is down twards you, 2nd up away from you, 3rd staight down form 2nd, and Reverse is twards you and up.
This is what I was thinking of, I don't know if there were any other trannys with shift on the colum, but some one might correct me.
Old Aug 7, 2005 | 11:13 AM
oldhalftons's Avatar
oldhalftons
if reverse is up and towards the driver, its a clark overdrive.
It a strong transmission that most people confuse with the later weak OD aluminum case transmission.
they have a slipyoke tailhousing like a auto (and use a auto transmission mount), but the tailhousing is cast iron.
Its a ford toploader case with 6 holes instead of 8 and a bulge in the passenger side to clear the OD gear. unmarked hurst shifter with a crome handle.
no creeper gear though.
Old Aug 7, 2005 | 11:31 AM
lmhans4440's Avatar
lmhans4440
oldhalftons, that sound more like it. He said reverse was over twords driver and up. Did these transmissions come stock in these trucks?
Old Aug 7, 2005 | 11:32 AM
oldhalftons
yes they were only in 78-79 1/2-ton trucks and 77-81 vans
Old Aug 7, 2005 | 11:34 AM
MBBFord's Avatar
MBBFord
I told you I could be wrong about the OD part.
Yeah they came stock in the trucks, my buddy had a 79 With the shift on the colum transmition.
Old Aug 7, 2005 | 11:37 AM
oldhalftons
but they aren't column shift. they are floor shift with external linkage just like a 4spd toploader.
pattern will be
R 1 3
. 2 OD
gear shift will be located on the drivers side of the transmission hump like a 4spd in a car..
Old Aug 7, 2005 | 11:54 AM
lmhans4440's Avatar
lmhans4440
I should have told you it's a 2 wheel drive.
Old Aug 8, 2005 | 07:30 AM
2020's Avatar
2020
Yep,that's what my 79 had in it orig.They were not a real strong trans.but the OD really helps MPG.We had 2 of them in the truck while my dad owned it(he bought it new) and we got probably 70-80k out of each one.The OD went out of both of them.
Old Aug 9, 2005 | 11:32 AM
lmhans4440's Avatar
lmhans4440
Thanks Guys, I bought the truck. It is a 3-speed with overdrive and a hurst shifter. I already bound up the shifter. It is a clark overdrive. The pickup rus and drives great. Thanks for all of your input.
Old Aug 11, 2005 | 02:29 PM
fordflaresides's Avatar
fordflaresides
My 1978 has the following shift pattern it's a 3.03 3-speed.
R 2
1 3
