electric choke hookup
Old Aug 7, 2005 | 01:34 AM
66 custom cab man's Avatar
66 custom cab man
Hello:
I've dropped a 77 302/c-4 in my 71. Before I had a heat activated choke, now I'm using the Motorcraft 2barrel with electric choke. I need to add power. Any advice on where to tap into? Or, since I'm in California, can I run it disconnected and just rotate the adjustment wide open?
thanks for any advice.
Ken
Old Aug 7, 2005 | 12:26 PM
LxMan1's Avatar
LxMan1
Tap into the stator wire coming off of the alternator. This is how the factory does it so that it only gets voltage while the engine is running.
Old Aug 7, 2005 | 10:31 PM
66 custom cab man
Great Idea
Thanks for the help. I noticed after I posted my original question that it has the fitting for exhaust manifold fitting too. Which works best, and if I use the electrical choke, do I have to cap the heat fitting?
Ken
Old Aug 8, 2005 | 10:34 PM
LxMan1's Avatar
LxMan1
I have used just the electric part with no problems. You shouldn't have to plug the opening on the choke unless it has vacuum sucking in it.
Old Aug 10, 2005 | 08:06 AM
LilDuke's Avatar
LilDuke
What about the heat riser pipe(?) coming off the manifold?
Old Aug 11, 2005 | 07:58 PM
LxMan1's Avatar
LxMan1
You talking about the one to the air cleaner?
Old Aug 11, 2005 | 08:41 PM
LilDuke's Avatar
LilDuke
Yep, the one that comes off the passenger side.
Old Aug 13, 2005 | 12:15 AM
LxMan1's Avatar
LxMan1
That is there to keep the carb from icing up in cool, damp weather.
