Block Heater
Old Aug 6, 2005 | 09:44 PM
dorsetmerv's Avatar
dorsetmerv
Block Heater
I have never used a block heater before as i am new to diesel, any pitfalls in using one in a 1988 7.3?
Old Aug 6, 2005 | 10:11 PM
RA122225's Avatar
RA122225
Banned
Nope, nothing. I have one on my 1991 7.3L
Old Aug 6, 2005 | 10:19 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The electric bill will be higher, also use a good heavy cord. 12 guage wire is OK for 25 feet, should be 10 guage for longer than that but less than 100 feet.
A heavy duty timer to turn the block heater on about three hours before you want to start the truck will save some electricity.
Old Aug 6, 2005 | 11:57 PM
PLC7.3's Avatar
PLC7.3
One pointer for all the block heater users......
If you think the block heater is toasted, first always check the wire(s) just behind the 120 plug at the grill. The power wire will break there first, so do a continuity test on the plug and wiggle the wires to see if continuity is intermittent, if it is replace the plug end. If your still not getting the continuity go down to the Bheater and check it is plugged in and do a continuity test across the power pins there.
Old Aug 7, 2005 | 07:28 PM
dorsetmerv's Avatar
dorsetmerv
Thanks for your help guys.
Old Aug 7, 2005 | 08:08 PM
jboard's Avatar
jboard
Hi, Here in WV it can get pretty cold in the dead of winter does it hurt to leave the truck pluged in all night? Thanks, Jeremy
Old Aug 7, 2005 | 10:08 PM
fellro86's Avatar
fellro86
nothing but your pocket book for the electric bill....
Old Aug 7, 2005 | 10:14 PM
Dave Sponaugle
Only the electric bill. Most block heater run in the 1000 watt neighborhood.
I have seen 600, 800 and 1200 watt in the several that I have replaced in my truck over the years.
I used to have mine on a timer, but since I never know when I have to go plow snow or spread salt I just plug mine straight in to the oulet now. That way I am always ready to roll at the drop of a snowflake.
If you always leave at a regular time in the morning, having the block heater come on three hours before you want to go will save a lot on the electric bill thru the entire winter.
If you have your glow plugs and batteries working good, the block heater is not really needed till it goes below 0, but it is nice to be able to start defrosting the windows as soon as the engine fires.
Old Aug 7, 2005 | 11:20 PM
jboard's Avatar
jboard
ok thanks i just didnt know if it would burn up the heater element because of being left on all night.
Old Oct 23, 2005 | 05:26 PM
tyrfryer's Avatar
tyrfryer
So where do I get a CHEAP block heater? (Don't flame me, I'm just starting to look.)
Old Oct 23, 2005 | 05:32 PM
fellro86's Avatar
fellro86
there are several types, cheapest is either the ones that go in the lower radiator hose or the ones that have to go in the side of the block. I don't much care for the ones in the radiator hose myself. There is another type that is a self pumping kind of, it mounts in the heater hose or the drain plug on the block, and t's into the heater hose, and circulates by percolation basically, we have used them on the farm tractors for years. Most any parts store should have any of the heaters.
Old Oct 23, 2005 | 05:37 PM
tyrfryer's Avatar
tyrfryer
I've seen a couple like described on e-bay, I'd like to go with one that goes in the block, though, and can't find those on e-bay for my 7.3. Got more looking to do.
Old Oct 23, 2005 | 05:58 PM
fellro86's Avatar
fellro86
The one I got for my 6.9 came from NAPA to the tune of $45, and isn't always available. My factory unit looked like someone took it out when the motor was rebuilt, and it blew out on one of the coldest nights on and ice slick 3 hours from home with a loaded trailer... not much fun. It goes in the plug right above the starter. Take a look, you may well have one already there, as far as I know, all the diesels come with them from the factory. You may have the infamous cord problem...
Old Oct 23, 2005 | 06:34 PM
jeffdoerr's Avatar
jeffdoerr
Unless you are on call for something, it is a waste to leave your block heater plugged in all the time. GEt a good timer, something that will handle 1000watts. I think mine cost me $20 at KMart. I just used a xmas tree light timer, just had to check over a few and get the highest watts. If you leave at 7 inthe morning, set the timer to come on at 4am and off at 7am (or 7:15). It wont hurt the truck to leave it plugged in all night, but its a waste. We as a nation need to learn how to conserve and wuit wasting soo much. No wonder fuel tripled in the last 4 years, everybody has to drive a full size 4wd over powered gas guzzler to take their kids to soccer and to pick up mail. I bet 95% of these poeple NEVER use the 4wd out of neccesity. Not knocking you guys, just got off on a rant. High fuel prices have made it hard on us who REQUIRE the need of a full size 4wd vehicle for work.
Dont knock my mustang, it gets 29.5mph (hwy and 24 around town) when I dont have my foot shoved through the floor......
Old Oct 24, 2005 | 01:11 PM
95-F250's Avatar
95-F250
Guys have told me that if you leave the heater controls in the defrost settings
when you park and plug in that natural convection of warm water helps keep the front windshield frost free. Never tried it,I never plug in, it usually doesn't get that cold here.
