Injector pump adjustments
Old Aug 6, 2005 | 01:39 PM
TXF250's Avatar
TXF250
How do you adjust the amount of fuel the injector pump injects in to the cylinder? Have a F250 1994 7.3 IDI diesel with factory turbo. I had a article on this at one time and lost it. Any help would be appreciated.
Old Aug 6, 2005 | 01:54 PM
crazylegs's Avatar
crazylegs
I think you adjust the amount of fuel that the injector pump delivers. don't quote me on this but I think if you open the hood step up on the bumper lean over and look down on the pump you will see on the left side an arm this is the fuel adjustment. the adjustment is made inside the cab with a pedal on the floor it will be the one on the far right you can hear the adjustment real well wiht the engine running.
just kidding. I couldn't resist actually one of the reason I am looking right now is to get the same info. to adjust fuel pressure.
Old Aug 6, 2005 | 03:52 PM
farmnfly's Avatar
farmnfly
Check out this guys homepage he has done alot of playing around with his 6.9 http://www.members.shaw.ca/k2pilot/ this should have what you need.
Old Aug 6, 2005 | 05:48 PM
TXF250's Avatar
TXF250
Thanks
I have been looking for this web site thank you very much. I going to try it now and see how it works.
Thanks again
Old Aug 6, 2005 | 06:59 PM
PLC7.3's Avatar
PLC7.3
TX F250 please read the fine print re a pyrometer........increasing fuel can up the normal temps to piston melting temps........you don't want to go there....
Old Aug 8, 2005 | 10:53 AM
TXF250's Avatar
TXF250
pyrometer
What should the temperature run? Where do you take the temperture at or install the pyrometer meter sensor?
Old Aug 8, 2005 | 02:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The best place to install a pyrometer is in the exhaust manifold.
Mine is in the rear of the drivers side manifold just above where the cross over pipe connects. There is plenty of room inside the pipe there for the thermocouple and this is about as close to the piston as you can get the probe.
The piston will start to melt at 1250 degrees, so I always keep mine under 1200 so there is a safety margin.
When you adjust the pump also pay close attention to small adjustments also.
Do you have any black smoke when at wide open throttle now?
If so you will only want maybe one flat of the allen screw. Two flats and it will look like a freight train.
A three inch turbo outlet and complete 3" exhaust would probably give you more power than the fuel pump adjustment will, and it will let a lot more heat out of the engine resulting in lower EGT's (exhaust gas temperatures).
Old Aug 10, 2005 | 07:26 AM
TXF250's Avatar
TXF250
Not trying to add more fuel. Trying to cut back get more MPG. Is there anything I need to be careful about when cut back and leaning out the fuel that injected into the each cylinder?
Old Aug 10, 2005 | 04:59 PM
Dave Sponaugle
Much easier to only give it 1/4 throttle while driving it.
That way if you get in a position where you must have more power than that, all you have to do is mash the pedal.
Old Aug 13, 2005 | 03:33 PM
Dieseldan7.3's Avatar
Dieseldan7.3
to adjust the fuel take the triangle plate off the passenger side of IP. put a socket on the crankshaft pulley and turn it until you see the allenhead screw through the window in the ip behind the plate. Then stick a 5/32 allen in there and turn it to the right to increase the fuel. I turned mine up about a 1/4 turn and its just right. Not too hot but it will roll clouds out the stacks at full throttle.
I listened to the smart crackerheads in this forum and bought a pyrometer. Just put the probe in the driver side manifold, easy to get to. I put mine right where the gas blows out of the second cylinder from the front.
redsadam
Jul 14, 2013 01:22 PM
Dieseladdict
Nov 21, 2005 02:04 AM
wycowboy
15
Apr 21, 2004 11:47 AM
earlsfork
Sep 25, 2003 11:40 PM
