carrier baring??
Old Oct 23, 2002 | 09:28 PM
cjcathey2002's Avatar
cjcathey2002
carrier baring??
where is a carrier baring? i know its somewhere after the tranny on the way to the rear axle on my 2wd 77 ford. also how much would one cost? also how much for a new u joint? i am wondering because my truck had a bad vibration when driving, and the shop said those were the problem. i just want to know how much money i am looking at for the parts. thanks.
1977 F250 460
C6 Hedman Headers
Dual 40 series
edelbrock performer
holley 4160
msd 6a and blaster coil
Old Oct 23, 2002 | 10:20 PM
1 Ton 4X4's Avatar
1 Ton 4X4
carrier baring??
Your truck only has a carrier bearing if it has a
2-piece driveshaft. It's in the middle of the 2
driveshafts. It's been a while since I've replaced
one, so I don't remember the cost. I would recommend
replacing the carrier bearing and all 3 u-joints at
the same time (if one's bad, the others are soon to
follow) and grease 'em often.
Ron
'79 F350 4x4
'79 F250 4x4 Super Cab
'77 F150 4x4 (daughter's "POWERHOUSE")
gotta get a Bronco next!!!
Wife wants a new Excursion...wallet's screamin'
like a banshee!!!
Old Oct 24, 2002 | 09:45 AM
Mark76f250's Avatar
Mark76f250
Post carrier baring??
CJ:
Just like Tom said the carrier bearing suppots a two piece dive shaft. It is pressed on the forward drive shaft and is attached to cross member with a couple of 3\8 bolts. I just replaced mine this past weekend. It cost me $14.58 plust tax.
To replace it, you will need to remove both drive shafts. Put the shaft with the carrier bearing in a vise, then use a long punch and hammer to remove the bearing from the drive shaft. Becareful not to harm the machined surface on the driveshaft with the punch or hammer. Take the old carrier bearing with you to the parts house so they can match it up. The parts guy said that Ford used three slightly different bearings but one is the most common. I had the most common and you probably will to. Still, taking the old one with may save an extra trip.
Installation of the new is the exact reverse of removing the old. Spend a few minutes to clean the spines on the shafts and apply a thin coat of fresh grease.
Hope this helps and good luck.
Old Oct 24, 2002 | 10:31 AM
fatdaddy's Avatar
fatdaddy
carrier baring??
jberylecrider
20
Oct 25, 2024 05:57 PM
owenstout
May 12, 2015 06:02 PM
kickingber
Offroad & 4x4
Sep 3, 2009 12:54 AM
blucollar4xford
Offroad & 4x4
20
Oct 15, 2008 08:19 PM
fcfirefighter05
Sep 23, 2007 09:28 PM
