a few questions
Old Aug 5, 2005 | 10:33 PM
60'BigBlue's Avatar
60'BigBlue
a few questions
ive been looking in to building a performace 460 to put put in a hot rod or my 60' f350 could i see an example of a performance orieantaited engine
Old Aug 5, 2005 | 11:43 PM
ivanribic's Avatar
ivanribic
How much performance do you want and how much money do you plan to spend? Start there and we'll have something to work with, otherwise monsterbaby will show you a $50,000 Prostock Hemi and I'll post up a 604ci hemi with a blower. Seriously though, what's the budget looking like and what do you plan to do with it.
Old Aug 5, 2005 | 11:51 PM
60'BigBlue's Avatar
60'BigBlue
budget it low 5 grand i have a block and heads intakes gone and oil pans missing out of a 80's f250
Old Aug 6, 2005 | 01:11 AM
whd507's Avatar
whd507
a stock 68-71 460 made 360 hp/450 lbs ft. and can be reproduced with stock parts pretty reasonable, and long-lived, start from there is my suggestion.
Old Aug 6, 2005 | 01:40 AM
monsterbaby's Avatar
monsterbaby
next question is whats your idea of performance? if you looking at a 400-450hp engine you won't need $5k. Otherwise I would say either port the D3 heads that should be on that engine put in a set of small dish pistons, deck the block to zero deck for quench, run a good cam, and intake combo with headers and a properly sized carb and no problem.
Or if you want to spend the 5k then go with a stroker like a 514 or 521 (stroker kits around $1400 are easy to come by) then put in the good cam, and have someone work over your heads or better yet if your not afraid of alum heads buy a set of TFS street heads, med hyd roller cam, edelbrock performer rpm or victor intake and 500+hp shouldn't be a problem and the 5k budget won't be busted or atleast not to badly
