Sponsored by: Real Truck
What to look for?
Old Aug 5, 2005 | 01:34 PM
G-Bone's Avatar
G-Bone
What to look for?
Hey all , newbe G-Bone here.
I figure this would be the place to go for this question....
I am looking at buying a 2000 F250 super cab/ short bed
7.3 pwrstrke with a 6 speed manual tranny.....75,000 mi.
My question is multi part.....
1) Does anyone know of common problems with the 2000's
that I should know about before going in.
2) What should I look for or check in regards to the engine and tranny
when I go to inspect.
Any help would be greatly appriciated!!
G
Old Aug 5, 2005 | 01:38 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 5, 2005 | 07:01 PM
99f350sd's Avatar
99f350sd
Good year and all. I would check front end parts bearings, and ball joints and tierod ends. Also how well it was maintained? Take it for a good test drive.
Watch warped rotors.
Welcome!!
Dick
Old Aug 5, 2005 | 11:42 PM
El Gato's Avatar
El Gato
Do not forget to check for play in the steering wheel. That was often a problem for 99s, but Ford did improve their boxes in 2000. Also, get the CARFAX done and see if it was ever registered back east or in the north where salt was used on the roads. Of course check its under-carriage for extensive rust damage.
Old Aug 6, 2005 | 10:41 AM
G-Bone's Avatar
G-Bone
Thank you for the advice.
My many days of searching have just begun.
I don't want to go below the year 2000.
Should I stay away for the 6.0 engines?
Old Aug 6, 2005 | 12:46 PM
mrxlh's Avatar
mrxlh
While that comment about the 6.0l engine, could possibly start world war 3, no they are not all bad. As mentioned, carfax is a wonderful Idea, also an Oasis report would be the key in finding out if the truck has been a warranty queen. You can have the VIN run over at flat rate tech.
Welcome to the fold.
I would suggest doing a few serches in the 7.3l forum, as the 6.0l forum has a thread specifically titled that, Mileage and problems, its right at the top.
Now for the news you didn't want to here. This 7.3 vs. 6.0 has been litterally beaten to death here. At times it seemed like Democrats vs. Republicans on some of the threads, instead of 7.3 vs. 6.0. While the 6.0 has had some unusual growing pains, most of the better dealerships are getting their techs up to speed, and are actually much more of a joy to deal with than say a year ago.
This being said, I am on my second 6.0. I had a 03 F250CC 2WD, with 60,000 on it when I traded it last month, I had 4 bad injectors, FICM, HFCM, replaced under warranty. Never did I have any of the surge, wire harness chafing, or many of the other drivability issues many here are having, and mine, like Tim's was a late 02 built truck. I also did have the intercooler hose blow off, but thanks to this site, I knew exactly how to fix it on the side of the road with minimal tools. The only reason that I traded in the 03 was to get a 4X4, and the pricing and interest rate on the 05's was to hard to pass up.
Ryan
