Aerostar Ford Aerostar
choking when accelerating
Old Aug 5, 2005 | 11:07 AM
enerxy's Avatar
enerxy
hello everyone,
need help on my 89 3.0l. auto. my problem started a week ago. driving on a state freeway the van started choking while accelerating to a halt. engine is still running it just wont go. chokes when when gas is depress switch to neutral and slowly press on the pedal until it gets better and drove home for another 4 miles.
change a few things like spark plug wires, plug, dist. cap, distributor,air filter, fuel filter, and pcv. but did not do any good. i can drove it for a few minutes and it start choking again worst on a uphill.
i don't see any map/maf on a chilton manual
Old Aug 5, 2005 | 11:21 AM
tom_foreman's Avatar
tom_foreman
Welcome!!!!
Just a guess but I'd check the fuel pressure. I'm sure other more experienced folks will chip in with their advise.
Old Aug 5, 2005 | 12:16 PM
Bear River's Avatar
Bear River
Former ******
Check for com puter codes and do an KOEO test.
Old Aug 5, 2005 | 12:48 PM
enerxy's Avatar
enerxy
thanx tom,
i should have mention that i changed the fuel pressure regulator too.
enerxy
Old Aug 5, 2005 | 12:52 PM
enerxy's Avatar
enerxy
thanx,
i'll do that today.
Old Aug 5, 2005 | 01:26 PM
bertha66's Avatar
bertha66
When was the last time you change the fuel filter?
Old Aug 5, 2005 | 01:41 PM
enerxy's Avatar
enerxy
just got back from autozone computer code check and all system pass
Old Aug 5, 2005 | 01:42 PM
enerxy's Avatar
enerxy
two days ago
Old Aug 5, 2005 | 01:50 PM
tom_foreman
Have you ran any fuel injector cleaner through it?
Old Aug 5, 2005 | 02:06 PM
enerxy's Avatar
enerxy
no not yet
Old Aug 5, 2005 | 02:50 PM
bertha66's Avatar
bertha66
I have Taraus SHO that was doing something like this, fuel pump was getting weak. It would work, but with low pressure.
Old Aug 5, 2005 | 03:48 PM
Bear River's Avatar
Bear River
Former ******
Thats why you need to check the fuel pressure. If your reading is low, replace the fuel filter. If it is still low, replace the fuel pump.
Old Aug 5, 2005 | 09:27 PM
Racerguy's Avatar
Racerguy
Could also be a plugged catalytic converter.
To test it you can unbolt the y-pipe from the manifolds and drive it.
Old Aug 5, 2005 | 10:33 PM
tom_foreman
I forgot about the Cat. That happened to my Miata. Fine at idle. Give it gas and it just wouldn't go. Try to rev the engine in neutral and see what happens.
Old Aug 6, 2005 | 12:26 AM
enerxy's Avatar
enerxy
the cat might have done the job
thank you all for helping. the cat might have done the job. it drives ok now after cat removal.
enerxy
