Update of e40d Trans leaking
Old Aug 5, 2005 | 08:39 AM
Fast Fords's Avatar
Fast Fords
Thanks everyone for your help. I pulled the trans pan and found a very dirty filter and replaced it ,now the trans is doing just fine turns out when Ford put in the reman trans they must not have flushed the lines causing the trans to load up and dump the fluid out of it when I hooked the camper up and pulled it down into reverse. I also changed the fuel filter and distributer cap(MSD) and rotor button. Need a set of wires now any Recommendations? Also putting on a water pump today.
Old Aug 5, 2005 | 10:12 AM
jim henderson's Avatar
jim henderson
I would keep a record of this, especially if the tranny is still under warranty. If the tranny dies because it was contaminated by dirty lines after the dealer did the work, I would stick them with it.
If you still have the filter it might be worthwhile to keep it in a plastic bag.
Good Luck,
Jim Henderson
Old Aug 6, 2005 | 12:55 PM
Fast Fords's Avatar
Fast Fords
Well Jim I found out that the trans is not under warranty anymore,so I quess I'll hook up the camper and make some local runs with it and see what happens next.Thanks I'll am going to record everything I do to it.
