I have a 2002 f-150 supercrew, lariat 5.4, 55000. the pwr windows stopped working tonight. They worked fine earlier in the day but now nothing. Its just the windows, even the sunroof. Everything else is fine. I checked the fuses looked good. Not sure what do try next. Plus I don't have an owner's manual to see a fuse diagram. Could anyone help? Yes I did a search.
Trav
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
My '02 S'crew does the same thing, but it usually clears up pretty quick. It seems something is sticking, either in the "lock out" on the driver's door or the pasanger door. Good luck & Welcome!
But usually dosn't the drivers side control still work if the window lock is engaged? I hope its a simple fix. And thank you for the welcome! I used to spend all my time on the toyota forums but I traded my two toys in for a Ford. I hate to say it but I never had these problems with the toys. But you can't beat the power of that 5.4L Triton, man its nice.
Trav
They all may appear good, but I know in the factory we use to get blown fuses that would appear good on the top of the fuse but would be blown down further towards the terminals. We use to half to pull the fuse and inspect it with a light.
I took off the control panel and took it all apart. Everything was normal. I double checked all the fuses under the hood again. Even switched the 30 fuses. nothing helped. Still having the same problem. Someone HELP!
