Sponsored by: Auxito
First problem
Old Aug 5, 2005 | 12:19 AM
Duec66's Avatar
Duec66
First problem
I have a 2002 f-150 supercrew, lariat 5.4, 55000. the pwr windows stopped working tonight. They worked fine earlier in the day but now nothing. Its just the windows, even the sunroof. Everything else is fine. I checked the fuses looked good. Not sure what do try next. Plus I don't have an owner's manual to see a fuse diagram. Could anyone help? Yes I did a search.
Trav
Old Aug 5, 2005 | 06:04 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 5, 2005 | 11:20 AM
mblayton's Avatar
mblayton
Did you check both fuse boxes, engine compartment and lower drivers dash ?
Old Aug 5, 2005 | 04:27 PM
Duec66's Avatar
Duec66
Yes, even though I don't know which one controls the windows. I just checked them all. All looked good.
Any more suggestions?
Old Aug 5, 2005 | 04:47 PM
triton_2002's Avatar
triton_2002
Pop off the driver's side window switches (firmly pull the whole assembly and it pops out) and check for loose/dirty connections.
Old Aug 5, 2005 | 06:21 PM
Duec66's Avatar
Duec66
I'll try that when I get home and get back to you. thanks
Old Aug 5, 2005 | 07:13 PM
retired2001's Avatar
retired2001
My '02 S'crew does the same thing, but it usually clears up pretty quick. It seems something is sticking, either in the "lock out" on the driver's door or the pasanger door. Good luck & Welcome!
Old Aug 5, 2005 | 07:32 PM
Duec66's Avatar
Duec66
Talking
But usually dosn't the drivers side control still work if the window lock is engaged? I hope its a simple fix. And thank you for the welcome! I used to spend all my time on the toyota forums but I traded my two toys in for a Ford. I hate to say it but I never had these problems with the toys. But you can't beat the power of that 5.4L Triton, man its nice.
Trav
Old Aug 5, 2005 | 07:43 PM
mblayton's Avatar
mblayton
They all may appear good, but I know in the factory we use to get blown fuses that would appear good on the top of the fuse but would be blown down further towards the terminals. We use to half to pull the fuse and inspect it with a light.
Old Aug 5, 2005 | 09:34 PM
Duec66's Avatar
Duec66
Which fuse controls the windows so Im sure Im checking the right one?
Old Aug 6, 2005 | 12:02 AM
Duec66's Avatar
Duec66
I took off the control panel and took it all apart. Everything was normal. I double checked all the fuses under the hood again. Even switched the 30 fuses. nothing helped. Still having the same problem. Someone HELP!
Old Aug 6, 2005 | 01:30 PM
Duec66's Avatar
Duec66
I just noticed this morning that the two dome lights don't work either if that helps.
Anyone had this problem?
Old Aug 6, 2005 | 03:08 PM
mblayton's Avatar
mblayton
Try fuse 110 in the box in the engine compartment, it is a 30A. This is what my master wiring diagram book from the factory is showing.
Old Aug 6, 2005 | 06:12 PM
Duec66's Avatar
Duec66
thanks ill check it out when I get home.
Old Aug 7, 2005 | 12:53 PM
LxMan1's Avatar
LxMan1
Don't the windows usually us a circuit breaker and not a fuse???
