Sponsored by: Real Truck
Step Lights
Old Aug 4, 2005 | 11:01 PM
MikeTEC's Avatar
MikeTEC
Step Lights
For safety purposes, we would like to have some lights installed underthe rocker panel of our 2002 F-250 CC to light the step bars at night. We would like to have them wired to come on with the dome light.
Any light kit recommendations? Thanks so much for your help!
Mike
Old Aug 4, 2005 | 11:10 PM
Bear Hunter's Avatar
Bear Hunter
You mean like this?
19.00 fog lights from Autozone. The cheaper the light the broader the light pattern which is what you want for this purpose.
Closeup of the light. I aimed them so it would illuminate the opposite side of the truck due to my amp steps being in the way
Relay mounted on the firewall
Old Aug 8, 2005 | 01:05 PM
bkmf250sd's Avatar
bkmf250sd
Bear Hunter, I'm looking to hookup some LED lights. How did you wire them to come on with the dome light. Is there a wire in the harness that runs from front to back? Any information would be appreciated!!
Old Aug 8, 2005 | 03:16 PM
MikeTEC's Avatar
MikeTEC
Thanks, Bear Hunter, for the pictures and recommendations. That is the concept I had in mind. I have found some amber waterproof 1"X2" boat trailer side marker lights that will work.
I prefer amber to white lights as amber illuminates better during fog and drizzle, when you need good vision for getting in and out of the truck. Again, thanks so much! Mike
Old Aug 8, 2005 | 07:35 PM
Bear Hunter
bkm
...under the door sill inside the cab, look for the black wire w/blue tracer. that's your dome light signal.
Here's how to connect the proper poles to your relay.
# 85 of black w/blue tracer
# 86 goes to ground
# 30 fused power
# 87a to lamps
And where ever you wanna put the relay and lights
My relay is under the hood on the firewall.
Mike,
...anytime...post some pics when your done...I'd love to see it.
Headviking
6.4L Power Stroke Diesel
Aug 6, 2014 10:05 AM
Force21
Electrical Systems/Wiring
Aug 10, 2013 01:53 AM
BADAS03SVT
Jul 8, 2008 06:55 AM
TXHillCountry
Jan 18, 2007 07:39 AM
Benoit1967
2004 - 2008 F150
18
Aug 3, 2004 11:07 AM
