steering column length (darksider)
Old Aug 4, 2005 | 04:32 PM
ferguson777's Avatar
ferguson777
When we talk about suitable donor steering columns for 53-56s being 30 to 32 inches in length - from where to where is that 30 - 32 inch measurment being taken?
Thanks,
Old Aug 4, 2005 | 05:06 PM
jniolon's Avatar
jniolon
old and in the way
hey cuz...
here's the poop
I bought a 30" but with header clearance I needed a 32" had to build an extension for it.... so look at your steering linkage clearances before you order... or scrounge or whatever... the guys at IDIDIT.com are really helpful..
john
Old Aug 4, 2005 | 05:12 PM
theGman's Avatar
theGman
I would think that if you aren't sure, you're better off buying a shorter column, since it's easier to add a piece of double D shaft to make it longer than any vice versa option.
Old Aug 4, 2005 | 06:06 PM
4tl8ford's Avatar
4tl8ford
Ferrgy
I would think that YOUR steering column should be about 2" long.
That way you head would be below the vision of all but a very few.
Again, just my thoughts.
Old Aug 4, 2005 | 07:27 PM
ferguson777
Guys,
Thanks.
Looking at a steering column for the young lad's Ch*vy and thinking if it doesn't work for his application then maybe it'll work for mine.........
Penn Dick,
Ya gotta start cutting back on the meds! I couldn't figure out what that mean't.....But then subtle never worked on me (ask both wives).......
Later,
Old Aug 4, 2005 | 08:48 PM
Earl's Avatar
Earl
It means yer ugly. At least in his opinion - consider the source.
Old Aug 5, 2005 | 09:52 AM
ferguson777
George,
"it means you're ugly"
Hey, that was an insult.
Penn Dick,
I resemble that!
Old Aug 5, 2005 | 01:44 PM
4tl8ford's Avatar
4tl8ford
Sorry 'bout that, yesterday was your turn in my Fish Barrel.
Old Aug 5, 2005 | 04:05 PM
e william's Avatar
e william
I used a 32" Ididit with a Toyota steering box and had to only join with the u-joint...didnt need and shafts inbetween. Sits fairly well with the big cushioned bench seat but I'm gonna replace the bench with some 97 GP buckets.....dont know what kind of changes I'm in for, but I'm sure I can fab up some seat brackets to line it up.
Good luck with your install. Ed
Old Aug 5, 2005 | 10:30 PM
51dueller's Avatar
51dueller
I resemble that!
So you look like it then?
Old Aug 6, 2005 | 06:19 PM
ferguson777
Nathan,
Glad to see someone caught that self-effacing play on words. Guess it was too cerebral for Penn Dick.
(That'll keep PD busy with his Funk & Wagnal for a while)......
