Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
What is...
Old Aug 4, 2005 | 03:22 PM
Jason8705's Avatar
Jason8705
What is...
What is the compression ratio and how is it determined???
Old Aug 4, 2005 | 04:31 PM
pitrow's Avatar
pitrow
I must assume your talking about the compression ration of an internal combustion engine? It is technically the ratio of the volume of the combustion chamber when the piston is at top dead center and when the piston is at bottom dead center.
For example, if you have a combustion chamber that holds 100 cc's with the piston down and 10 cc's with the piston up, then you have a 10:1 compression engine.
Old Aug 5, 2005 | 09:29 AM
sevenL4's Avatar
sevenL4
Compression ratio is the ratio between the total volume of a cylinder and its combustion chamber when the piston is at BDC (the bottom of it's stroke) and the total volume of the cylinder and its combustion chamber when the piston is at TDC ( the top of its stroke).
I'm sure that's what PITROW meant but he misspoke when he mentioned only the combustion chamber.
Old Aug 5, 2005 | 12:38 PM
pitrow's Avatar
pitrow
Sorry if I caused confusion. In my mind the whole cylinder is concidered part of the combustion chamber.
Old Aug 5, 2005 | 01:49 PM
Jason8705's Avatar
Jason8705
That's fine you both gave me info i didn't know. Thanks for your help!!!!
sparkkky
2004 - 2008 F150
Aug 21, 2011 03:02 PM
SuperSnake
Maryland Chapter
68
Jul 9, 2008 12:17 PM
JByrd1173
Dec 11, 2004 03:35 AM
3.8 & 4.2L V6
Jan 23, 2003 10:01 AM
bigsnag
Nov 22, 2001 10:35 PM
