I have a 1988 F250 and I am having some trouble on starting first time in the day. It has been warm in the day and the nights are mild at the moment. I am having to try 2 or 3 times before it will start but once it has done a couple of miles it will start straight away. After the intial difficult start there is a little bit of grey/white smoke which soon clears. Could this be flooding? I wait for the light to go out and the clicking to stop before I try to start.
Any ideas would be appreciated.
If your cold solenoid is working, or weak. Mash down on the pedal and release once your key is on. it helps a lot. also try to press the pedal down 1/4 way and see if that helps.
mine was doing the same thing. turns out seven out of eight glow plugs were bad although they were replaced by the guy I bought it from 3 months ago before it became mine. I know it was done as I helped him do it. He liked to use ether when it wouldn't start right up and it fried them. Replaced them and not a problem since.
my 89 also starts hard. I changed all 8 glow plugs 2x. I put in Champion plugs and then found out that the Motorcraft/beru plugs are MUCH better to use. So far I have changed plugs, fuel filter, injector return lines and installed a 2nd battery. The truck will roll much faster now, but my gp light will only stay on for 4 to 5 seconds and a cold start will take 2 or 3 tries. A warm start will fire once it rolls for 5 or 8 seconds. A HOT start (hitting it after being shutoff for only a few minutes) will fire right up, maybe roll-over 2 or 3 times. I am getting a little discouraged with this thing, but I have to keep at it, this is my winter truck. Any help would be greatly appreciated.
If anybody is interested, I have a total of 10 good glowplugs for sale or trade. Cheap.
the gp relay is behind the air cleaner, mounted at the back of the intake. It has a plastic cover over it. It is pretty simple in design and performs much like a starter solenoid. When I first got my truck, it would just click like crazy. I found and replaced 1 bad glowplug and the relay worked kinda like it should, only problem is, it only stays on for 4 or 5 seconds. There are some great threads on how to test and rewire the controller, just do a quick search on it.
