Hell Wig Front Sway Bar
Old Aug 4, 2005 | 10:56 AM
MR.X's Avatar
MR.X
Has Any 1 Put One On I Have A 04 V10 And I Tow A Lot Im Going To Order The Rear On Friday Do I Need The Front 1
Thanks Mr.x
Old Aug 4, 2005 | 11:47 AM
rlh68050's Avatar
rlh68050
Don't you already have a front one?.
Old Aug 4, 2005 | 12:53 PM
MR.X's Avatar
MR.X
i have not looked i will have to go look now i seen the add for it so i did not know if i have the front i know i do not have the rear it sags bad with my boat on hooked on it
Old Aug 4, 2005 | 01:57 PM
rlh68050's Avatar
rlh68050
Sway bar will do nothing for rear end sagging. You may need some airbags, or Timbren rubber springs.
Old Aug 4, 2005 | 02:54 PM
MR.X's Avatar
MR.X
every one on her has told me to get the sway bar and it would help the sag i don not know what to do then i strated a thread befor asking where the best place to get them and how they woked for them and i have read on past things every says to put it on to help this problem
Old Aug 4, 2005 | 06:44 PM
V10_X's Avatar
V10_X
It will help with how the X tracks while towing. It is a night and day change in general ride quality too with the rear sway bar. Just make sure when you install it, that it is centered over the differential. I got mine from JC Whitney for $150 including shipping. I tow a 28ft Travel Trailer and it made a world of difference. If you need help installing it I can take a few pics so you can at least see how it looks after installation. I can email them to you or try and post them to the forum. Its really easy to install but a little word of warning, the directions that came with the sway bar from Hellwig were awful, I could barely read them. Luckily I know a ford master mechanic that helped me out.
I also installed a set of new shocks too which also helped alot.
I tow with an equalizer tow bar which brings the weight off the tounge of the trailer and distributes it over the entire length of the X and trailer, that's what eliminated the sag in the back on my rig.
Hope this helps,
Jeff
Ki4mrx
Jan 10, 2015 12:25 PM
navydochm2
Mar 14, 2013 08:43 AM
MR.X
Jan 4, 2007 06:33 PM
MR.X
Aug 17, 2005 01:38 PM
Torque1st
Sep 8, 2002 12:57 PM
